How to remove antenna if its up?
Old Dec 25, 2020 | 03:21 PM
88BLKTransAmGTA's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7 L98
Axle/Gears: 3.77
Antenna will not come out. - The antenna wont go all the way down so I am attempting to remove it but there is just not enough room because of the antenna being up. Any suggestions?
Old Dec 25, 2020 | 06:35 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
Re: How to remove antenna if its up?
Remove the other bracket from the antenna, and maybe jack the car up?
Old Dec 25, 2020 | 06:43 PM
Johnny Gun's Avatar
Car: '88 GTA
Engine: 355 SBC, AFR 195 heads, Stealth Ram
Cut it off.
Old Dec 26, 2020 | 02:35 PM
Engine: 5.7 L98
Axle/Gears: 3.77
Originally Posted by Johnny Gun
Cut it off.
Yeah that's what I am going to have to do. I already bought a stock manual antenna and hawks motorsports shorty 8" antenna and their billet retaining nut. So the stock power one will just go into the closet for future repair.
Old Dec 26, 2020 | 05:22 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Its still bolted to the bracket!
Old Dec 26, 2020 | 07:48 PM
Engine: 5.7 L98
Axle/Gears: 3.77
I took the one bolt out and disconnected it from.the bracket that holds it up. Is there another bracket?
Old Dec 26, 2020 | 08:19 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Thats it, except for the grommet for the pigtail/ant cable. Have you tried pushing down the antenna itself. Maybe jack the car up like suggested.
Old Dec 26, 2020 | 08:42 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Un-clip the ECM wiring harness "U" retainer ( behind the kick panel )... then push ECM wiring "bulge' thru the body and into the fender well. You should be able to then push the harness low enough behind the fender well to get the power antenna past it.
You can also remove the 2 10mm screws that hold the rod type bracket to the antenna body ( visible / still installed in the picture you posted ) to help the removal process.
Old Dec 26, 2020 | 08:50 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
The antenna pigtail/cable are on a separate grommet. Just above the ECM harness.
Old Dec 27, 2020 | 08:20 AM
Engine: 5.7 L98
Axle/Gears: 3.77
I thought it has enough slack it isn't effecting getting the bottom turned toward the opening. But I am going to remove tho and see if it helps.
I tried pushing the antenna down but it would only go about half way. Even tried tapping it with a rubber mallet 😆.
BadBilly442
Convertibles
Feb 7, 2020 06:33 PM
johnw999
Jan 18, 2020 04:18 PM
User Name:
Sep 10, 2006 09:45 PM
92B4C3051LE
Aug 2, 2003 02:26 AM
Camarokid01
Oct 8, 2002 02:02 AM
