How to change the 4x6's out of the front.
Old Mar 19, 2001 | 11:24 AM
Camaros4_life's Avatar
I am going to put acutic 4x6s and 6x9 where the stock ones are. I can get the 6x9, but the 4x6 look alot tougher to get too. How in the hell do you get to them. I seems that you got to go under the dash? any help would be appreated.
Old Mar 19, 2001 | 11:36 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
There's an article in the tech section of this website that has a full set of instructions.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Mar 19, 2001 | 05:31 PM
TooSlowRS's Avatar
its pretty simple, just look under the dash on the left, unscrew those guys, then follow along near the bottom of the pad by the gauge plate and you'll see another one. then get the ones at the rear of the pad by the windshield. thing slides right off.
Old Mar 20, 2001 | 01:58 AM
MADOGIROC's Avatar
Yea its pretty tricky. I recently installed new 4x6's and what you really need is the right tools.
Old Mar 20, 2001 | 04:57 AM
Belker's Avatar
In my '91 Camaro, changing the front 4x6s is as easy as it gets. There are four screws in the defroster vents (use 7mm socket) and another (about) 6 screws under the front edge of the dash. Remove these, tilt your steering wheel down, and lift/pull the dash pad off. (Be careful with the pad because it's easy to damage.) You should now see the speakers. 4 screws hold them down. This is a REALLY easy project.
billybob6110
Feb 11, 2016 10:41 AM
86CamaroDan
Sep 29, 2015 10:08 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
FormulasOnly
Sep 6, 2015 10:42 AM
