Ohm's
Old Mar 22, 2001 | 11:41 AM
KlayBuRn's Avatar
Ohm's
OK, heres my deal, i have 2 15' Rockford Fosgate Power DVC's, 500 RMS a voice coil
i have a bd1000a1, as i was told that would be the best...how would i hook this up? what Ohm would the amp be running? both subs are 4 ohms...what would be the total wattage(RMS) going to each coil?
and with the bd1000a1, what is the lowest OHM it is stable at? and those mono amps, do they just have the terminals on just mono or what?
Old Mar 22, 2001 | 12:06 PM
cbpldc's Avatar
Wow, that should sound pretty nice. Wire them in parallel (both pos go to pos in amp) and they will draw a 2 ohm load from the amp. I think that amp should be 2 ohm stable.
Chris Payne
'92 RS
'84 S/E
Old Mar 22, 2001 | 12:43 PM
KlayBuRn's Avatar
yea, so its 2 ohms when you have Single Voice Coil subs and you wire it with boths pos's to mono pos and both neg's to mono neg? thats 2 ohms right?
or...was you talking about running both the positive's from the DVC to the mono on the amp?
i guess i just really need an OHM lesson...
heh
Old Mar 22, 2001 | 01:17 PM
FormulaJoe's Avatar
An ohm is a mearsure of resistance in current. With two 4 ohm subs in this case, you can get a 2ohm load by wiring them in parallel, or you can get an 8 ohm load by wiring them in a series configuration. The equation for parallel is R1R2/(R1+R2) or (4x4)/4+4= 16/8=2ohms. This goes for any 2 resistances in parallel. If the two resistance values in ohms are equal (4ohm and 4ohm) then you simply cut it in half (4/2=2)
FOr a series configuration, you simply just add the two resitances to achieve the total resistance of the circuit.
L98, 3.27 9-bolt, Hooker shorty headers, custom 2.5inch Y-pipe, no cat, 3inch 2chamber flowmaster, JET AFPR, Ported MAF, Best ET: 13.86 @100mph. 1.99 60'
17 inch ROH "ZS" wheels. 17x8.5(front) and 17x9.5 (rear). Firestone Firehawk SZ50s. 245/45/zr17s and 275/40/zr17s. T56
On the way... Radar Blue 89 Formula, T56, Ram Jet 430, Ram Air, 17inch ROHs.
Old Mar 23, 2001 | 12:17 PM
MelloYello's Avatar
I was wondering if anyone knew the formula to determine the increace of watts due to reduced resistance (ie 300w @ 4Ohms = Xw @ 2 Ohms = Yw @ 1 Ohm). If there is a formula, then thats what I would like, simply because I dislike guessing or just assuming that halfing the ohm load would double the output (it doesn't, right?). Anyway, thanks for all your help
1990 Firebird Formula 350 speed density TPI; K&N, air foil, throttlebody coolant bypass, underdrive pullies, MSD 6AL, MSD HEI coil, 8.8mm wires, adjustable fuel pressure regulator, Hypertech Thermomaster chip, 160* thermostat, fan switch, B&M stage 2 shift kit, Edelbrock 1&5/8 headers, gutted dual cats, Flowmaster 80 series muffler, 3.73 posi rear end
[This message has been edited by MelloYello (edited March 23, 2001).]
Old Mar 24, 2001 | 10:24 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
P(watts)=V^2/Z(impedance)
for example:
V=10 volts
Z=4 ohms
therfore:
10^2/4=25watts
if Z is half of 4=2
then:
10^2/2=50watts
This is ideal. There are other factors to take into account, but saying half the ohms will double the power output is somewhat true.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 3/14/01)
There can be only one!!
Fanatic1074
Oct 3, 2022 05:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
lewandom
Oct 1, 2015 08:15 AM
ironbmt
Sep 27, 2015 06:00 AM
Shane87irocz
Sep 22, 2015 06:21 PM
