New sub box
Old Mar 23, 2001 | 03:32 PM
Supercharged87Camaro's Avatar
New sub box
Ok. Heres the thing. I just bought a pair of the new Infinity Perfect 12" subs. However, the previous box i had was for 2 10s. NOw, i was wondering is it would be better to cut the holes bigger, or to buy one of those boxes they have on Ebay for like 70 bucks. Also if anyone has a box that they bought from there, please let me know how you like it, and how the subs sound in it. Thanks
Old Mar 23, 2001 | 03:39 PM
87firebird's Avatar
If you cut bigger holes the sound wont be good at all. You need the right amount of air space(only if its a sealed box). If its not a sealed box then it probably will work to cut bigger holes.
Old Mar 23, 2001 | 11:51 PM
9177's Avatar
whats your total airspace per sub if its around .9 - 1.2 you should be o.k. it will aleast work for a standby perfect 12's don't need alot of space in a sealed box
Old Mar 24, 2001 | 08:20 AM
Todd 92 Z's Avatar
If you cut the holes bigger then stuff the box with poly-fill it should sound good.The poly-fill slows down the sound waves inside the box and makes the sub perform like it was in a bigger box.The rule is about a pound of poly-fill per cubic foot of air space. Go to the crafts section at Walmart they sell sell 1 1/2 pound bags for a couple of bucks,thats where I got mine.
Old Mar 25, 2001 | 06:18 PM
Belker's Avatar
Like was said ... if you got 1 ft3 for each sub it will sound fine.
Old Mar 25, 2001 | 10:23 PM
92fire-audio's Avatar
I have those subs.. They are right about the airspace, but if you are not close to the 1.0 ft3 of space they need per sub, DO NOT buy a 70 dollar box.. Save your money and have a shop either custom build your box or build it yourself. I've heard those subs in a prefab box and I've heard them in a box made specifically for the sub and if you judged by the prefab box then you'd be dissappointed that you paid whatever you did for the sub.. Those are EXCELLENT subs, why not give them at least a GOOD box?
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Ed1LE
Sep 30, 2018 09:14 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Zell1luk
Sep 29, 2015 10:36 AM
