4 ohm mono
Old Mar 29, 2001 | 09:47 PM
350iroc-z's Avatar
4 ohm mono
This can be obtained with 2 single voice coils that are 8 ohm each or with 2 dvc that are 4 ohm each. The dvc would be wired like this <a href=http://www.jlaudio.com/tutorials/wiring/images/2dvcseries.gif>http://www.jlaudio.com/tutorials/wiring/images/2dvcseries.gif</a> and the svc like this <a href=http://www.jlaudio.com/tutorials/wiring/images/2svc.gif>http://www.jlaudio.com/tutorials/wiring/images/2svc.gif</a> Right?? Just making sure I havent lost my mind.
www.350iroc-z.com
[This message has been edited by 350iroc-z (edited March 29, 2001).]
Old Mar 29, 2001 | 10:36 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
As far as impedances are concerned, a dual voice coil sub is the same as 2 single coil subs. Parallel-wiring two 8 ohm loads results in a 4 ohm load. Parallel-wiring two 4 ohm loads results in a 2 ohm load. Series wiring will make an addative load. So, if you wire a pair of subs like shown in the first JL picture, you'll get a single 4 ohm load if each coil is 4 ohms.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Fanatic1074
Oct 3, 2022 05:57 AM
Elephantismo
Feb 13, 2019 12:51 AM
BADNBLK
Brakes
Oct 6, 2015 02:51 PM
lewandom
Oct 1, 2015 08:15 AM
ironbmt
Sep 27, 2015 06:00 AM
