two tens facing each other...
Old Mar 29, 2001 | 01:58 AM
irocz_ca's Avatar
when two 10" subs face each other 2 feet apart in mono, the sound waves won't cancel each other out. right? planning to put a 10" in each rear side panel and have them facing each other. thanks for any input...
Old Mar 29, 2001 | 08:12 AM
KlayBuRn's Avatar
dude, if your gonna mess with 10's, dont put them in the side panel, your gonna lose all the sound...build a box and put them in the hatch, sound SO much hella nicer...
Old Mar 29, 2001 | 10:45 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
As long as you build a good enclosure for each, you'll be fine. Having them facing towards each other will not cause a problem. As long as they are in phase, they will still be pressurizing and rarefracting the cabin simultaneously.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Mar 29, 2001 | 06:57 PM
irocz_ca's Avatar
thanks for replying. will try to build seperate fiberglass enclosures for 2 10s JL Audio which may be sufficient for the volume available in the side panels.
Old Mar 30, 2001 | 10:39 AM
HrdRockA4305's Avatar
I'll agree with Jim85IROC on this one, generally speaking if they are in phase it will still be compressing the air the right way and should sound ok, but i also think a box in the hatch would be better than side panels too. Just my 02.
dbrochard
Exterior Parts for Sale
Oct 10, 2015 01:03 PM
drumstixer
Sep 29, 2015 03:02 PM
Numbah-1
Brakes
Sep 21, 2015 05:18 AM
gta892000
Sep 16, 2015 12:37 AM
tgp1990
Sep 4, 2015 06:24 AM
