I NEED AN ANSWER NOW!!!!!!!
Old Mar 18, 2001 | 07:27 PM
88tam's Avatar
How do I tell where the remote turn on wire or input or whatever it is, is? Which wire is it, how do I connect to it, ect... I am in the process of installing my amp and I just realized that I didn't know which on the remote turn on wire went to in the back of the head unit. I have an Xplode cd player if that helps at all.
Old Mar 18, 2001 | 08:23 PM
Black82Z's Avatar
it should be labled at the back of the head unit, if not it should be a blue wire coming off the unit. If you cannot find which wire it is, just take a multimeter, plug the head unit in and turn it on then find a wire that puts out 12v from the back. You can use the power antenna wire if there is not a remote wire
Old Mar 19, 2001 | 07:05 AM
dallasiroc's Avatar
If you do not have a remote turn on for the amp try the red wire on the back of the radio
this wire should be a 12v accessory lead.
DO NOT use the power antenna wire!!! If you do you will find that your amp turns off when you play a cd or tape.
[This message has been edited by dallasiroc (edited March 19, 2001).]
Old Mar 20, 2001 | 05:37 AM
cbpldc's Avatar
Actually, it depends on which radio it is. If the radio has both an accesory wire and a power antenna wire, then you definitely want to use the accessory wire. If it only has power antenna wire (like some cheaper stereos) then feel free to use it. Just my 2cents.
Chris Payne
'92 RS TBI
'84 Firebird S/E
Old Mar 20, 2001 | 01:13 PM
FiReBReTHa's Avatar
WATCH OUT!!!!!
sony exPLODE!!!
lol. sony.... lol.... explode....lol.....
91 FireBird 305 V-8
no true mods,
ghetto rigged cold air intake,
People dont have a soul, its just something parents made up to frighten little children, like the boogie man, or micheal jackson..."
GheTTo Riggers INC.
We Make Mcgyver look Like Crap
Old Mar 21, 2001 | 04:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I think the last Xplod I did had a blue wire, like Black82Z said. I hear some newer car radios actually put a little fuse on that wire. Oh, it's not a good idea to push more than 2 amps (or 1 amp & 1 equalizer, etc), off the remote turn-on lead. If the lead isn't fused, you can burn up the turn-on circuitry in the radio. If you need to run more than two, use a relay.
Oh & on the Xplod I did, the "remote/pwr antenna" wire was good for the amps. The radio doesn't shut off the antenna when you go to CD, so the amps stay on.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Apr 2, 2001 | 12:36 AM
Gen X Maro's Avatar
on sony products blue is your remote wire and coming off your factory harness is a dark blue wire as well..worse case scenario you can wire a remote out of your fuse box to a fuse that runs off the acc position of the ignition....unless its been cut though it should be there
1992 RS 25th anniversary..305 tpi conversion,slp headers,jet chip,3 inch flow master exhaust,3:73 richmond gears,big block style hood,80 degree tint,black outs,b&m megashifter,high rise spoiler,and much more.
Stereoioneer 8000R with organic screen,2 memphis 1000d amps(1100rms each) 4 memphis shp 12's 2 capasitors,audiobahn line driver,memphis crossover,stinger dry cell battery.
Old Apr 2, 2001 | 11:19 PM
evilho7810's Avatar
Dont use the antenna wire. I did and the amp will turn off whenever you put it on cd.
Old Apr 3, 2001 | 03:34 PM
FORD Rustangs -R- Us's Avatar
again..as im the third person to say this or so..only certain CD players do that. my blaupunkt i use the remote wire and its fine
grngryoutmyway
Oct 18, 2016 05:48 PM
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
