3 10"'s vs 1 12"
Old Apr 4, 2001 | 09:46 PM
crows_camaro's Avatar
3 10"'s vs 1 12"
What can I put in my car to hit harder than 3 10" mtx 4000 series pushed by a Profile amp that rmses at 600watts in a Jeep Cheroke?
Will a HX2 do it? I am going to put one in my car(I know I keep saying that but my friend is out of state and it is at his house). If it will out hit it the mtx's what amp should I use? I want it to me louder and out hit my friends set up but to look like I have less in my car. In other words I want it to look like I got really good stuff that probalby didn't cost as much but is better. I don't care if it cost that much as long as it is better than his. Please help me decide what I need to put in my car to sound better, hit harder, and be louder than 3 10" 4000 mtx's.
Thank you for all you help,
Joey
P.S. will a RF 250 power my hx2 somewhat decently until I get something better?
Old Apr 4, 2001 | 10:20 PM
92fire-audio's Avatar
I would say that 1 12 is going to be pretty weak compared to 3 10"s.. 3 10"s are often louder than 2 12"s..
If you want to be louder than 3 10"s your going to need at least the same amount of power and more surface area...
Old Apr 4, 2001 | 10:51 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Here's my opinion:
Take the money you'd spend on 3 10s, buy 1 12 and a better amp. That profile amp is your limiter here, not the subs.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Apr 5, 2001 | 06:37 AM
cbpldc's Avatar
The HX2 should do it, but you will need more juice. Another issue here is that your friends Cherokee has more space and is more open. You can make any cheap amp and sub combo sound amazing in an SUV. I set up an 87 Blazer with 2 Jensen 10's and a Pyramid 300 watt amp (I didn't buy or recommend the stuff, I just put it in) and he out pounded some much higher dollar systems, just because SUV's are set up for this kind of sound. I had half of a PPI 4100 powering a Phoenix Gold X-max 12 inch subwoofer in my camaro for awhile, and it slammed like crazy. You are going to have to spend some bucks to outpound your friend. Sorry.
Chris
Old Apr 5, 2001 | 11:56 AM
GTAMAN63's Avatar
cbpldc,
You were able to make a Jensen sub sound GOOD?!? That's amazing! :lol Three 10's is hard to beat if setup properly. In my opinion, if you were to hookup up 3 12's with the same efficiency to the same amp, the actual db increase would be minimal. Is your box sealed or bandpass? If it's sealed I'm willing to bet 2 of those 10's in a bandpass would outhit 3 in a sealed with that amp.
Barry Izold
89 T/A, GTA
Modified 350/T-5
Old Apr 5, 2001 | 03:31 PM
dallasiroc's Avatar
I have heard one eclipse aluminum out pound any 3 10s I have ever heard.
Oh and I am running a PPI a600.2 and 3 10w6s
Old Apr 6, 2001 | 06:29 AM
cbpldc's Avatar
Yeah, I made a Jensen sub sound pretty decent. They hit fairly well for a short amount of time. In fact I had an old Jensen paper cone 12 in a bass tube in the trunk of my '78 Mercury Grand Marquis and it hit pretty darn good, for the money invested, sounded muddy though. I've done a lot of systems for poor teenagers, so I have a little experience with bang for the buck. Actually a bandpass box would hit harder only in a few certain frequencies, depending upon the subs and how the box is tuned. That is why I despise having bandpass boxes in my cars, because they aren't musical at all, but we'll save that arguement for theory 101.
Chris
Old Apr 6, 2001 | 11:24 AM
Jims83TA's Avatar
I think that three 10" infinity subs would kick a$$. I have heard 2 10" infinity's in my cousins altima, and they sounded great. They hit hard, and had a lot of bass to them. Just be ready to tighten all those screws in your car, because they will definitely rattle every loose bolt in your car. I am planning on getting just 2 10" infinity's for my TA.
Old Apr 8, 2001 | 02:31 AM
Sean's Avatar
I have 3 10's in my camaro and they out pound my bro who has only one 12 in his!!But we are using different makes then what u will be using so i guess the only to know for sure is to try it!!
Old Apr 8, 2001 | 10:55 AM
Sean
[Reply w/Quote] I have 3 10's in my camaro and they out pound my bro who has only one 12 in his!!But we are using different makes then what u will be using so i guess the only to know for sure is to try it!!
Diferent make? I will be using my 86 camaro. I am just wanting my system to be better than my friends in HIS jeep. Sorry If I wasn't clear that I am putting the hx2 in my camaro and wanted to be better than the jeep.
Old Apr 9, 2001 | 06:16 PM
Sean's Avatar
No i mean different makes of subs and amps then what u will be using
Old Apr 10, 2001 | 03:40 AM
da BEAST's Avatar
Car: 99 F350 Dually 97 Chevy Venture 97 Honda Accord 89 Mercedes Benz 190 1987 TRANS AM GTA
Engine: Brand new 350 Crate motor
Transmission: Beefed up 700R4
<p align="center"><small><small><img src="http://www.geocities.com/nucarsounds/hbp310.gif"
width="500" height="230" alt="HBP310.jpg (2993 bytes)"
Need a good deal? Look me up
Check me out for Hott DEALS on all of yuor audio needs Both home and car. Mobile video is also available!
Old Apr 10, 2001 | 03:41 PM
87ColdAirIroc-Z's Avatar
I had 3 JL audio 10's in my car and they sounded excellent. Now i have 2 HX2's in my car with a better amp and they are not as loud but hit a little lower. I am going to put my 3 10's back in my car.
87 Iroc-Z, LB9, performance exhaust, modified MAF & airbox
Old Apr 11, 2001 | 07:29 AM
2hx2's?? How did you have enough space. Each require about 4 ft3. Do your boxes have correct air space? If so what are you doing with the box and speakers?
