GTA Steering wheel control interface - Now working in 2024
Old Jan 14, 2024 | 08:34 AM
Larry J's Avatar
Hello to all,
I realize this is a long winded previously discussed topic. However, here is a fresh development that many may find very exciting! Have you ever looked for a steering wheel control interface for your third gen with no success? Do you have the steering wheel controls pictured below? This may be the most important read of your day.
I have successfully prototyped an interface that is smoothly and seamlessly communicating from this steering wheel below. This works with both Pioneer and Sony aftermarket radios with wired remote inputs. This input being the 1/8" (3mm) jack.
This has been in development for over a year. Currently the prototype is installed in my personal 1988 GTA. I am happy to make a production run of these if there is enough interest to keep the price reasonable. It is about the same size as most later model SWC units. It fits in the dash or radio pod neatly.
So, if your interested in using your factory steering wheel radio controls with an aftermarket modern radio, send me a message with your contact info. I will keep records of all who may be interested and go from there. Obviously the more interest we have in this, the faster it can / may progress.
Please feel free to ask questions here on this thread and I will be happy to respond them as soon as possible. I would like everyone to benefit from the questions so we can take this journey together.
Happy driving everyone.
Old Jan 20, 2024 | 09:08 PM
89 GTA 355's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7
Re: GTA Steering wheel control interface - Now working in 2024
89 GTA with Alpine radio w/remote 3.5 jack.
How does your prototype work?
Old Jan 21, 2024 | 06:05 AM
Larry J's Avatar
How does it work
My interface connects to the two wire plug from the steering column harness that was plugged in to the back of the factory radio. It also connects to 12V power, ground and has an 1/8" plug to the aftermarket radio wired input. The signal from the horn pad is received and decoded by a microcontroller. It then applies the necessary signal output through the 1/8" stereo jack to the aftermarket radio. The incoming coded signal is nothing industry standard (at least that I have found) so it does not have a name. I call it GM / Pontiac proprietary. Even the tech support folks at PAC and AXXES had no idea what GM was thinking during that era.
Thanks!
Old Jan 21, 2024 | 07:15 AM
89 GTA 355's Avatar
Engine: 5.7
So do you have these available for sale? If so how much? Are there any tests that need to be run on the horn pad/column turn signal switch? I'm not sure if my setup is working correctly. I'm interested in one of these if it will work correctly.
Thanks!
Old Jan 23, 2024 | 08:00 AM
Larry J's Avatar
Are these available for sale...
I would like to make a production run of them if there is enough interest. That would keep the cost down. At this moment the prototype is working with no changes required on the car or steering wheel assuming you have the above pictured horn pad and it it is working properly. If you still have the factory radio, confirm that it still responds and works with your horn pad connected. If you don't have it, check the signal wires (two, usually orange and gray) with Voltmeter. You should have 5 Volts orange to gray, at rest with everything powered up. Then when you press / hold any of the buttons, the Voltage should change / jump around.
So you are the first one to speak up and say you want one. Great! This is a start.
Old Jan 23, 2024 | 04:59 PM
89 GTA 355's Avatar
Engine: 5.7
Re: Are these available for sale...
Are you saying to measure the voltage between the orange wire and the black/tan wire from the 5 pin harness? I don't recall having a tan wire.. are you at the radio harness or the horn pad ?
Thanks, appreciate your assistance!
Old Jan 26, 2024 | 08:36 PM
Larry J's Avatar
These wires are on a plug at the back of the factory radio. Mine had a separate plug just for those two wires.
Old Mar 8, 2024 | 03:08 PM
Florida GTA's Avatar
Engine: 5.7 TPI
So what's the status with these? I wouldn't mind ordering one as well as my PAC system only works when the engine is off. Start the car and the controls become intermittent.
Old Mar 9, 2024 | 06:29 AM
Larry J's Avatar
Hello,
The status is this: The prototype is finished and operational. I would need many orders to produce and sell them at a fair cost. When I say fair I mean about $150 ea. This would require a few dozen at least to be produced in a production run.
PAC and others use completely different 1994'ish and later protocols that are easily adapted to thousands of vehicles across decades of technology. So their price can be a little lower of course as they will sell very high volumes of their adapters.
This adapter is compatible with an older protocol proprietary to GM / Pontiac that has never been supported by PAC and others.
So far you are the second person interested and I thank you for that.
Old Mar 9, 2024 | 05:58 PM
Big&BadGTA's Avatar
Engine: 5.7L L98 TPI
Transmission: 700r4 Automatic
This, the coolest thing I read on the internet in 2024
Old Dec 19, 2024 | 06:34 AM
Crzyflyboy's Avatar
Originally Posted by Larry J
Hello to all,
I'd be interested in more info.
I'm still restoring, so not on the top of my list at the moment, though hopefully soon!
Old Dec 19, 2024 | 07:30 AM
TransamGTA350's Avatar
Car: '89 GTA
Engine: ZZ6TPI
I am also interested.
Old Dec 19, 2024 | 08:21 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I've always wanted to do this
Old Oct 21, 2025 | 10:29 PM
4wealnGTA's Avatar
Old Nov 10, 2025 | 10:19 PM
4wealnGTA's Avatar
Anyone?
Old Nov 16, 2025 | 07:41 PM
Larry J's Avatar
Hello to all,
The problem is we would need a large order to go to production, probably 100 units. There just has not been enough interest. I truly thought there would be many more conversions yet to be done. I have stable code and a working prototype. I truly appreciate everyone's interest and comments.
What is the old saying? A day late, a dollar short?
Old Feb 9, 2026 | 02:21 PM
carattini's Avatar
Car: Pontiac 89 GTA
Engine: 350 TPI 5.7L V8
I would be interested....
Johnny Gun
Jan 6, 2022 01:58 PM
KRACKER JACK
Nov 22, 2021 07:15 PM
_87TA_
Jun 15, 2010 06:46 PM
88fastgta
Jan 11, 2010 09:14 PM
Darkshot
Jul 2, 2008 10:23 PM
