Cassette deck
Old Apr 15, 2024 | 11:14 AM
z28lro's Avatar
Car: 1986 IROCZ Z28
Cassette deck
Im trying to replace the belt in my cassette deck and i've taken out all the screws and the deck became loose but does not pull out. I cant find any other screws that may be holding it in place.
z28lro's Avatar
Car: 1986 IROCZ Z28
Re: Cassette deck
Old Apr 15, 2024 | 01:21 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Cassette deck
IIRC,there is a screw under the face plate-sometimes it is phillips head ,other times hex head
Old Apr 15, 2024 | 05:57 PM
z28lro's Avatar
Car: 1986 IROCZ Z28
Re: Cassette deck
I had taken it off and removed mostly all screws that i could see under it. I didn’t want to remove all of them so it wouldn't become complicated to piece back together. I had saw one under the top of the front frame. That screw was not accesible at all. Nothing could fit to get to it since it was under the frame. Hard to explain how it was exactly. Is it better to just take it apart all together?
Old Apr 15, 2024 | 08:19 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Re: Cassette deck
If you look at the radio from the front,... turn the radio so you can see the RIGHT side of the radio. There are (usually- not always ) 4 screws holding it in place,.. the 3 similar 1/4" screws and 1 very small screw ( 3/16"?) that gets installed from the RIGHT side. ( front right corner of the cassette mechanism.) You need a slim long socket to reach it.... if you're LUCKY it will be a phillips head screw and not a 3/16" screw. Be sure to disconnect the 2 electrical plugs.
* No cassette mechanism screws are hidden under the face,... don't need to remove the face to remove the cassette mechanism.
SOME radios do not have a 4th screw - but most do. Once the screws are removed push the back of the cassette mech forward with your thumbs while lifting UP. Once the back of the cassette mech gets raised up it's free & can usually then simply be pulled out of the radio. Sometimes the cassette mech gets stuck, usually due to the cassette mech "cover" hitting on the case, but sometimes just because of a "splinter" from a screw hole.
Old Apr 15, 2024 | 08:20 PM
John in RI's Avatar
Re: Cassette deck
Old Jun 10, 2024 | 01:44 AM
Extrafitkid's Avatar
Car: 1986 TRANS AM
Engine: LB9
Re: Cassette deck
These guys rebuilt may original radio with Tape deck $225.00 Plus one-year warranty happy with the service. Just FYI they have all the parts and put in new updated board and light along with repairing Deck.
M&R Electronics Inc.
5665 State St.
Saginaw, MI. 48603
U.S.A.
Call us at 1-800-343-1382
camaro211z28
Aug 29, 2012 10:36 AM
88gta_hiflyer
Car Audio
Dec 21, 2009 10:54 AM
sam356
Apr 8, 2007 12:53 PM
Crusin' 1980's
Car Audio
May 14, 2005 09:59 PM
1988-1992 Z 28
Car Audio
22
Mar 12, 2003 11:44 AM
