Does anybody have a unique install?
Old Apr 9, 2001 | 09:58 PM
JPrevost's Avatar
Car: 91 Red Sled
I'm tired of the 2 subs in the well. Does anybody have anything unique. Like a single sub install. If somebody could just post pictures of different thirdgen installs that would be great or give me a link. How about putting the stuff behind the panels?
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 9, 2001 | 10:34 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
This one is somewhat unique:
This is the system that I built for my friend's Trans Am.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Apr 9, 2001 | 11:25 PM
matthew's Avatar
Jim, that is a sweet install. how does it sound? Is that a 12d3? how long did it take for you to make it? what amps are those? sorry about all the questions, but I'm really interested in it!
PS-I need more details!!
yellow 86 Camaro
LG4 700R4
Pioneer head unit
Kenwood speakers
Infinity Beta Digital 300 amp
2 Infinity Perfect 12s
Old Apr 10, 2001 | 07:43 AM
Jim 86 Bird's Avatar
Car: '89 TA
Engine: LB9
Transmission: M5
here's my setup in my old bird. I've since then moved it into my TA, recarpeted black, put cloth over the sub cover, and moved the neon inside the amp.
otherwise, its still the same basic setup.
http://www.tcnj.edu/~esposit3
  • '89 Trans AM, 305 TPI, 5-spd
  • '86 Firebird, 2.8, Auto
Old Apr 10, 2001 | 09:39 AM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by matthew:
</font>
It's a 12W0. My buddy bought the stuff used. I wanted to smack him when I discovered that it's an 8 ohm sub.
The amp pushing the sub is a Kicker Impulse 652xi, and the amp for the highs is a Punch 40. Overall the system sounds real good, but that Punch 40 doesn't have an internal crossover, so I had to use a cheap high-pass unit that brought all sorts of noise into the system, so I was forced to use a ground loop isolator because my buddy is too cheap to spend money on a good crossover.
Anyway, the system pounds considering the pathetic amount of power that 652 makes. The box design and placement of the driver makes it get pretty loud. I'd say 125-128dB range.
The box took me basically a weekend on and off to complete. It's basically an adaptation to my usual design. I'm not happy with the top flush mount panel, but I finished it at 11:00 on a sunday night with a wood chip in my eye, so by that point a good fit wasn't my primary concern. He's happy as a clam so I'm not going to bother making a new flush mount panel.
The IROC Homepage
Old Apr 10, 2001 | 12:58 PM
myposcamaro's Avatar
mine is unique, its got frkkin' wires everwhere
kev
Old Apr 10, 2001 | 02:28 PM
dallasiroc's Avatar
I like the dowl rod holding the hatch up.
Old Apr 10, 2001 | 09:04 PM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by dallasiroc:
I like the dowl rod holding the hatch up.</font>
I have one in all of my cars It's my common "signature"
The IROC Homepage
Old Apr 11, 2001 | 01:38 AM
Mike Harvey's Avatar
If you wanna see unique check out my mosterous system, just click on my signature.
- Mike Harvey -
1986 Firebird S/E &lt;----------------FOR SALE
Old Apr 17, 2001 | 03:47 AM
JPrevost's Avatar
Car: 91 Red Sled
Mike those are some sexy amps. I plan on keeping my interior looking as stock as possible. I think I'm going to be the first guy to install a single 12" and 2 v12 amps into the side panels totally hidden. Has anybody installed a stealth system before or does everybody here go for show? I've had too many problems with my show setups (they get stolen). My last setup was awesome. Had a single sub in the middle and the amps were under a tint plexi window on an angle from the back of the back seat to the well. I then had blue neon shine on them and it looked awesome. It was also portable so I could take it out for the track. Well it ended up in my front seat in pieces so I said $%*# it, I'm just going for SQ and it's going to look all stock. The only problem is going to be the obvious custom kicks I'm building for my MB Quarts. I'm looking for a stock GM head unit so I can gut it for the face plate. I also plan on moving the battery to the back under the panels but I don't know how much room I'll have to work with. Please post more pics of unique installs.
  • 8" harm. balancer
  • Alston SFCs
Old Apr 17, 2001 | 12:50 PM
GndPrx's Avatar
I'm currently working on a rather unique f-body install.
3 amps in the very bottom portion of the well, 2 12" subs...one inverted where the compartment is on the drivers side and the second where the spare used to reside. Reworking the entire rear (from rear seatbelts back) out of fiberglass. The IDOne processor will be flushed into the dash right in front of the passenger's seat. 8's, 5's and horns for front stage with the 8's and 5's in the kicks.
Probably going to be close to a year before I finish it up in my spare time, but I'll post pics from time to time to let you see.
get creative, anything is possible with a little practice and a ton of fiberglass and bondo
Carl
CarAudio Resources
[This message has been edited by GndPrx (edited April 17, 2001).]
Old Apr 17, 2001 | 04:44 PM
88 GTA Notchback's Avatar
I did something similar to what GrnPrx did.
I had a 12 installed where the trunk "lock box" used to be, and the amp installed in the spare tire compartment. I had enough space to leave the spare tire in place.
88 GTA Notchback
A4 / 350
Stock
** New User Name**
Kill List:
95 Mustang GT
88 Mustang GT
94? Impala (real close)
97 Dodge Neon
86 Corvette
2000 Prowler
And more Civic's then I can count. Why do they even bother?
Old Apr 17, 2001 | 07:11 PM
CamuMan's Avatar
i bet i have something none of you have. not trying to sound ****y, but i don't think any of you have this.
if you look real closely, you will see something quite unique under the dash, below the Z28 emblem. ok. ok. i'll tell you. there image dynamics compression drivers (horns) with 8" midbass drivers in the doors. yeah, i know, the boxes for the 8's are ugly, but they do the job quite well. tons of mid bass up front. the horns give a kick *** front stage, unbelieveable SQ, and great seperation. the head unit is a pioneer premier P1R and i have one 10W4 in the back for real low bass. as for the amp, one PPI 6 channel with a whopping 50 watts a channel. i beleive in less is more. not sick power, but the ears tend to ring.
[This message has been edited by CamuMan (edited April 17, 2001).]
Old Apr 18, 2001 | 07:44 AM
GndPrx's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CamuMan:
[B]i bet i have something none of you have. not trying to sound ****y, but i don't think any of you have this.
</font>
I refer you back to my original post. 8's 5's and HORNS all under the dash
Hrmm, you're not too far from me if you are in Tamarac.
Carl
CarAudio Resources
Old Apr 18, 2001 | 07:46 AM
CamuMan's Avatar
sorry, didn't see that important part, but than you know how nice they sound. can be harsh at times, but all around nice sounding equipment. very nice install. you have talent and creativity. must have sounded great.
[This message has been edited by CamuMan (edited April 18, 2001).]
Old Apr 18, 2001 | 03:13 PM
dallasiroc's Avatar
Im sure everyone has seen this one but was reminded of it in the "Wall Post"
Old Apr 18, 2001 | 05:51 PM
yea i posted that site. Its pretty sick if you ask me.
if that aint unique, then define it for me.
kev
Old Apr 19, 2001 | 02:03 AM
jobryan26's Avatar
That's really cool. About 300-400lbs in the wall and a NOS. Anyone else get it?
'87 Trans Am:
(Engine)
305 TPI
180 Degree Thermostat
JET Fan Switch
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Full Kenwood Excelon System
Old Apr 19, 2001 | 06:57 PM
JPrevost's Avatar
Car: 91 Red Sled
The No2 must be for getting the same times he had before the wall was installed. That is overkill and I hate it when it comes to stereo. There is nothing exciting about that and I would hate it if my car came with a wall. Too much weight and my ears can't tell the difference, only a computer. My eyes can tell the difference between a 10 second car and a 16 second car. Anybody else have some unique thirdgen installs?
88 GTA Notchback, could you get pictures of the install? I'd like to see what that box looks like in the panel.
  • 8" harm. balancer
  • Alston SFCs
Old Apr 19, 2001 | 08:06 PM
hey, i totally agree. There is no need what so ever for twenty 10" subs in a car, a camaro none the less.
But however, if i was sponsered and did drive that car as a daily driver, just for competitions... then hell.. id definately do that. Especially if i was getting payed for it.
kev
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
kah992
Aug 19, 2015 02:55 PM
