24-bit D/A Converter vs Dual 1-bit D/A Converter
Old Apr 24, 2001 | 11:04 AM
Night Hawk's Avatar
I am comparing 2 Clarion Decks. One is the Clarion DXZ615 and the DXZ715. The DXZ715 is $100 more than the DXZ615.
The differences are that the 715 has 24-bit D/A concerters, the 615 has dual 1-bit D/A converters. Is there an audible difference between these two statistics?
The 615 gets better radio reception than the more expensive 715. The 715 has a dot matrix display.
If you were to choose between these two CD recievers which would you choose?
Old Apr 24, 2001 | 10:54 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Listen to them and decide for yourself whether the 24 bit DAC is worth the extra money. To me it is because I can hear a difference, but most people can't. But, there are other factors that matter more. We have a new JVC deck with 24 bit Burr Brown DACs, and the deck still doesn't sound as good as the Alpine 7863 with a 1 bit DAC, because the rest of the signal path within the Alpine is higher quality.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Apr 24, 2001 | 11:41 PM
chrisfrerick's Avatar
the multi bit convertors generally have a better low end responce and a much better signal to noise ratio. i would choice the multi bit one. my alpine 7909 has two 18 bit das and a signal to noise of 110 and thd of .002 see how your deck measures up. also some decks cheat to get a high signal to noise ratio by having a built in noise gate. my alpine 5959 changer has a signal to noise of 115 it has 4 20 bit da convertors.
Hotrodboba400
Dec 10, 2019 07:07 PM
customblackbird
Oct 1, 2015 04:30 PM
jer4251
Sep 16, 2015 11:29 AM
Camaro_383
Sep 11, 2015 11:28 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
