Could this fry my CD player?
Old Apr 30, 2001 | 08:14 PM
mcconahay37's Avatar
I just got my 3" exhaust put on today. The guy used oxy-acetelyne welding. He never disconnected the battery, and when I tried to use my cd player later on, it was totally dead. I heard that welding on a car without the battery disconnected will fry the electronics. Nothing else is dead. My lights, turn signals, etc still work. Just my cd player is dead. All the fuses are good and didn't see any loose wires. My cd player is still under warranty, but I just hope my amp is ok.
82 Camaro:
350, Erson cam, ported heads, Crane Hi-6 ignition, Accel supercoil, Comp Cams 1.6:1 rocker arms, TH350 tranny with 2500 stall.
SLP 1 3/4" headers
Old Apr 30, 2001 | 10:33 PM
Stoopalini's Avatar
If the guy use Oxy, then no, that would not fry your radio.
Acedeline is a gas and he would not have hooked up any wire clapms to your car.
Now, If he used an Arc welder, then it could have caused your problem, but I doubt it.
Thomas.
Old Apr 30, 2001 | 11:16 PM
That's what I thought but figured I'd ask anyway.
Old May 1, 2001 | 03:07 PM
Anybody have any other ideas about why it quit. What else should I check?
82 Camaro:
SLP 1 3/4" headers
Old May 2, 2001 | 08:48 AM
Stoopalini's Avatar
Have you pulled the CD player out and tested it directly to the battery?
You said all the fises are good; does this mean you checked the fuses in the fuse box AND any inline fuses up behind the radio itself?
I would pull the deck and test it on the battery. If it doesn't power on, then take it back.
Thomas.
RedLeader289
May 28, 2019 01:47 PM
PurelyPMD
May 5, 2016 04:57 PM
jrdturbo
Mar 31, 2016 02:58 PM
Linson
Oct 1, 2015 09:50 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
