How many Ohms?
How many Ohms?
Click Here For Diagram
Hey guys,
If three 4-Ohm, single voice coil subs are wired as shown in the diagram, what ohm load does the amp see?
Also, if the subs are rated at 300 watt RMS each, should I be looking for a 300 watt amp, or a 900 watt amp?
Thanks is advance guys!
Hey guys,
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
2.667 ohms, but you don't want to wire it like that. You've got the center and left sub series-wired, then those two are paralled with the one on the right. The sub on the right is going to get a disproportunate amount of power compared to the other two.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
I agree with Jim....bad wiring setup....either wire them all in series or all in parallel...if wired in series(negative to positive)then you would need a 900 watt amp to max them out...if in parallel then a 300 watt amp capable of a 1 ohm load...hope this is helpful...
Scott Downs
85 Trans Am
305 tpi/700r4
3.73 w/255/60R15
plain firebird nose(for better engine cooling)
T-Tops, pwr everything
been to about 140mph
Scott Downs
85 Trans Am
305 tpi/700r4
3.73 w/255/60R15
Elephantismo
Feb 13, 2019 12:51 AM
