Please help with clarion!!!
Old May 8, 2001 | 01:29 AM
evilho7810's Avatar
I've got a 7675 and when ever I turn on the radio it pops loud as hell same thing when i change radio stations??? Also I get ground loop now. I just took out a crappy sony head unit and it didn't do any of this. I've got a 5 channel clarion amp hooked up to all 4 of the interior speakers and a kenwood sub. Also if anyone has a clarion instruction manual that would help a lot. It's got 2 yellow fused (15 and 3 amp) wires a red wire and a black wire. I need to know what the 2nd yellow wire is for.
Old May 8, 2001 | 07:14 PM
evilho7810's Avatar
anyone please
Old May 9, 2001 | 07:07 AM
Neo's Avatar
Neo
Re do your grond job to get ride of the loop. It also might get rid of your poopins sound.
Mike Kenny
1991 Chevrolet Camaro RS 305 TBI
My Website
Administrator at Auto-Clubs.net
Moderator at ColoradoCamaroClubs.com
My Baby
Old May 9, 2001 | 07:57 AM
Stoopalini's Avatar
You definitely have a grounding problem. Redo the stereo and amp grounds first. If the problem remains, unplug the antenae and test it out. If it still remains, then you might have a problem with the deck itself.
About the 2 fused wires:
Is this your stereo?
If it is, their web site says this deck has a dimmer built in; so I would guess the 3 amp wire is for the dimmer.
If so, you could connect it to the wire that runs your heater/ac lights, or just leave it disconnected.
Thomas.
Old May 9, 2001 | 02:43 PM
evilho7810's Avatar
Yeah thats my deck and I found out the 2nd fused wire is for cnet.
Old May 9, 2001 | 02:44 PM
Stoopalini's Avatar
Cnet Is that some sort of Alpine control network? ...... for cd changers and such?
Anyway, glad you got it figured out,
Thomas.
Old May 9, 2001 | 03:27 PM
evilho7810's Avatar
Yeah it's for Tv's and cd changers things like that.
Well I soldiered the ground connection and the ground loop went away but there is still that loud *** popping.
Old May 9, 2001 | 04:28 PM
Stoopalini's Avatar
Cool! one problem solved ..... one to go
You might want to check your remote power wire then. Amps will usually pop pretty loud when they initially get power if there is no signal being sent to them yet.
Some of the high end amps actually keep the channels from becoming active until an audio signal is detected on the RCA's - this stops the pop.
Another way people get rid of the amp pop is to use a time delay on the remote wire to hold off powering up the amp until the deck sends a signal down the RCAs.
Are you running any of your speakers off of the deck itself? If so, disconnect power to the amp and see if you still get the popping.
I think you have a litle more troubleshooting to do before you can figure out why it's popping like that.
Good luck!
Thomas.
Old May 10, 2001 | 12:20 AM
Chris Luongo's Avatar
I never knew that second yellow wire was for the CeNet....anyway, still hook it up.
Both yellows: constant power
red: switched power
black: ground
Old May 10, 2001 | 03:00 PM
evilho7810's Avatar
I'm running all the speakers off a clarion 5 channel amp so i'm not using the internal amp for anything. I think I might try putting a jump wire between the remote and power on the amp to see if it still pops.
Old May 10, 2001 | 03:12 PM
Stoopalini's Avatar
Yea, that sounds like a good idea.
If you still have the problem with the jumper wire, then try disconnecting the speakers one at a time - testing in between - to see if you have a problem with one of the speaker leads.
Lemme know what happens,
Thomas.
Old May 11, 2001 | 12:11 PM
evilho7810's Avatar
Okay tried each speaker one by one each one poped and I tried the amp in another car and it worked perfect. I just put the sony back in and its all working now so i think i'm going to have to take that peice of sh)t clarion in to get fixed.
Old May 11, 2001 | 12:57 PM
Stoopalini's Avatar
Huh, sounds like the RCA pre-outs have a problem.
Is it a new deck? Under warranty?
Thomas.
Old May 13, 2001 | 09:11 PM
evilho7810's Avatar
Nope like a jackass I bought it used.
MikeDwhoROCZImports
Car Audio
18
Oct 5, 2001 06:44 PM
SillyWabbit
Car Audio
Aug 15, 2001 02:24 AM
evilho7810
Car Audio
May 10, 2001 12:23 AM
myposcamaro
Car Audio
Dec 16, 2000 04:00 PM
