Adding 6*9's......?
Old May 11, 2001 | 09:06 AM
CloudIROCZ28's Avatar
Adding 6*9's......?
I'm putting some 6*9's in some custom boxes just behine the seats I'm wondering would I be able to just run wire from my 6*9's in the Rear Quarters or run it to my reciever?? I have a Pioneer DEHP-47 and 4*6 JBL's in the front, and 6*9 JBL's in the quarters.....
IROC-Z
G92, LB9 305 TPI, 3.23
Old May 11, 2001 | 03:04 PM
cbpldc's Avatar
I think that would be a bad idea. You list that you have 2 JBL 6x9's in the rear. Are those in the sail panel where they normally go, and of so, what kind of 6x9's will you be putting in the boxes behind the seats? If you still have your factory 6x9's in the rear, just replace them.
To answer your question though, you could just piggy back them onto the wires of your existing 6x9's if you want 6 speakers. Just be careful not to burn up your reciever's amp.
Chris
Old May 11, 2001 | 10:47 PM
T/A Man's Avatar
Buy an amp and subwoofer, your system will sound much fuller. If you add to many full range speakers your sound will bet colored and the additional load on your reciever will only generate more distortion. I have a Pioneer DEH 77, the model one up from yours. I have it driving Infinity 4x6 Kappa Plates and Infinity 5 1/4 Components in the rear and I use the High Pass filters in the deck set to 125Hz and I have an Infinity Basslink powered sub crossed at 125Hz and it sounds pretty damn sweet. Its not bone shaking, but the sound quality and range is fantastic. I bought the Basslink on ebay brand new for 200 bucks too. They cost 400 bucks at Crutchfields.
Old May 13, 2001 | 04:36 PM
To Answer the Questions ummm yes I do have the 6*9 JBL DS965 in the Sail panel...I'm gonna add too more too JBL 6*9 in the back...... what should I do just route the wire from the Sail panel Will they sound just as good as the ones in the sail or worse.......I want to put 6*9 boxes back there because When I have the T-Tops Off I wanna have at least a little room without Too much clutter...and Maybe a lil better sound when there off.....
IROC-Z
Old May 13, 2001 | 05:11 PM
Jiffy's Avatar
[This message has been edited by Jiffy (edited May 13, 2001).]
Old May 13, 2001 | 05:12 PM
Jiffy's Avatar
<font face="Verdana, Arial" size="2">Originally posted by Jiffy:
I don't know why you want to put more 6X9s in, but if I was going to do it, I would put in a four channel amp and run all 4 6X9w off of it.
I put two 12 JBL subs, behind the rear seats, I just two singls 12' truck boxes on there back. SO the speakers face up. I still can store my ttops in there by just letting them sit in the dropout and lean over the hump.
As a side note, if you put any speakers in the back, get the hatchback tinted, Will save your speakers from sun dammage and theft.
</font>
Old May 13, 2001 | 08:19 PM
jobryan26's Avatar
I'm confused as to why you would want to install an extra set of 6x9's. What are you trying or hoping to gain by doing this?
<marquee>'87 Trans Am:
(Engine)305 TPI,180 Degree Thermostat,JET Fan Switch,TB Bypass,Accel 300+ 8.8 Racing Wires,Accel Super Coil,Bosch Platinium Plugs,Custom Ram Air with K&N,Removed Emissions Equipment & Cat.(Stereo)Full Kenwood Excelon System Member at kyfbodies.org
</marquee>
[This message has been edited by jobryan26 (edited May 13, 2001).]
Old May 13, 2001 | 10:26 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 14, 2001 | 09:08 AM
Actually How hard would it be to maybe put 6*9's in the front where the 4*6's are Has anyone done this.....? Before I meant to put 6*9's in back of the seat on the deck....but now I know that would'nt benifit too much....
IROC-Z
Old May 14, 2001 | 10:22 AM
Stoopalini's Avatar
Quality over Quantity!!
I can't stress that enough. Get yoursef a good amp and some kick a$$ speakers, and it will sound so much better than 4 half way decent 6x9's off the deck.
Example:
I have a Kenwood eXcelon x911 deck, a PPI 30x4 amp, and a RF punch 160 amp.
Speakers are 4" Diamond components and stock 6x9's pushed by the PPI.
For bass, a single 12" JL W0 pushed by the RF.
When I play my system for people, they are completely amazed that I am only pushing 30 watts per channel. I tested it with a Db meter, and I top out around 125 Db with no distortion or clipping.
If I were you, I would get some good quality 4x6's for the front, and a nice 4 channel amp.
It doesn't have to be a big amp (30 quality watts will be plenty) and keep the JBL 6x9's for now.
Just add a sub and you'll be set!
Thomas.
Old May 14, 2001 | 11:10 AM
Jim85IROC's Avatar
<font face="Verdana, Arial" size="2">Originally posted by CloudIROCZ28:
</font>
It would be a botched abortion at best. You'd have to modify and reconstruct the entire dash board, and for what? Speakers that still don't approach the sound quality of a decent pair of components.
The IROC Homepage
Old May 14, 2001 | 02:18 PM
Jim yer killin me here..... lol just a thought jezz
1987 IROC-Z
G92, LB9 305 TPI, 3.23, Bright Red with Carmine Interior, Pioneer DEHP47DH CD deck.2 JBL DS645 4*6 (F).. 2 JBL DS965 6*9 (S).. Soon to be 335 TPI...
Old May 15, 2001 | 02:32 AM
Tigger84TA89BIRD's Avatar
I have to agree with Jiffy, adding a four channel amp and run your 4 speakers with that, and add some kind of sub, the most spacesaving one would be an 8"bandpass tube, so you can still put the t-tops in storage..
89: stock 305TBI, strut tower brace, MSD6AL, k&n filters,
stripes by AutoTrim Design,
optima wheels,
Kenwood kdcx615s deck, MBQuart dkd146 4x6,
MBQaurt Q series components in custom plates in rear pillars
2 JLAudio 500/2 sub amps
2 JLAudio 300/2 mid/high amps
2 12" soundstream SPLMules in 4 cubic ft box
audiosource 3.1 control center/EQ
GO TEAM CAR TOYS!!!!
Ed1LE
Sep 30, 2018 09:14 AM
86IROC112
Nov 7, 2015 06:50 AM
SRKLEGIN
Oct 29, 2015 06:38 PM
KCG
Mid-Atlantic Region
Oct 25, 2015 06:57 AM
gord327
Oct 3, 2015 01:25 PM
