How do i hook up my cap?
Old May 26, 2001 | 10:32 PM
87Iroc-z's Avatar
Car: 1987 Z28
Transmission: 700-R4
I just bought a cap and it came with no instructions at all. Its a lightning audio 1.0 farad. I have a basic setup, 2 12's, amp, and cd player.
Old May 26, 2001 | 11:45 PM
espirocz's Avatar
Car: CTS-V & 89 Z28 vortech charged
Engine: LS6 & 383 charged stroker
Transmission: 6-speed & 5 speed
A cap is like a reserve of power so it just runs in line with your power wire. The cap has a positive and a negative. run the power wire across the positive side and ground the negative side. As with all grounds the shorter the better. And you will want to place the cap as close to the amp as possible so when it hits that bass note it can draw the power as quickly as possible. A cap will help a clipping amp when running full range.
Considering the danger of hooking up caps and I haven't played with one for a while you might double check my instructions not that I dont trust myself I just dont want any blame. You know, C.Y.A.
Iroc Z28 with several mods for domination of autocross courses. BFG T/A R1s for the courses and Yokahama AVS Intermediates for the street.
Old May 27, 2001 | 08:49 AM
87Iroc-z's Avatar
Car: 1987 Z28
So basically i ground the negative, run the power wire to the positive, then run another power wire from the cap to the amp. Makes sense and sounds easy enough. Is this right?
Old May 27, 2001 | 12:06 PM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
Caps are wired in parallel. One wire (4g) to + side on distribution block, other wire to - side of the block. Be sure to properly charge the cap before hooking up the power lines or else you'll welding the screws to the top of it.
86 T/A 5.0
93 Civic 1.6L
13.5 @ 100 mph
Old May 27, 2001 | 03:12 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Mista mentioned a very important step. You must charge the cap first, otherwise it will act like a direct short. Most new caps come with a resister to use when charging the cap. I use a test light. Hook the ground up, then instead of hooking the power directly to the cap, hook the power to one side of the test light or resistor, and touch the other side to the cap. The resistor sucks because it gets hot and you don't really know when it's done. With the test light, it stays nice and cool, and when the light goes out, you know it's charged. Then hook the positive directly to the cap and it'll all be peachy.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
gta892000
Aug 11, 2019 11:16 AM
69GTOby
Apr 18, 2016 02:34 PM
Stryker412
Sep 20, 2015 06:59 PM
84redta
Sep 19, 2015 09:58 AM
Saxondale
Sep 15, 2015 06:42 PM
