Cd player blowing my fuses?
Ok...so I just got my new 160 watt cd player hooked, and it seemed to be working fine for the first week...then my power hatch release wouldn't work..but I didn't think much about it cause that kinda stuff happens, but then my dome light wouldn't come on (new bulb) and now my power door locks don't work. Could my cd player be blowing my fuses?
Ok I had almost the same problem and first i thought it was something with my brand new cd player that i had put in but it wasn't!!
First change the fuse in the fuse panal cause it is most likly blowen!! Wait and see if it blows again if it does u have a short somewhere!! That fuse is used for the radio, power hatch,interior light and the light in the trunk where the well is , it could be used for power locks to but i don't have power locks!!! The short in my car was coming from the light in the trunk it that well cause my sub box was pressing into and causing it to short out and blow that fuse!! So all i did was disconnect that light and the fuse has been fine ever since!! If this doesn't work u are going to have to check all the other things that are on that fuse!!
Linson
Oct 1, 2015 09:50 PM
