anyone install 4 inch components set in the dash??
Old May 27, 2001 | 08:20 AM
CrazyHawaiian's Avatar
Car: too many ...
I know the dash usually accepts 4x6 speakers, but I was wondering if anyone had installed a 4" component speaker (like from polk or boston)? what did ya have to do to get the speakers to fit?
--- Current Daily Driver ---
Maroon 1989 Camaro RS - Crappy 305 TBI / Auto
Hypertech Stage 2 Chip (and 160/ThermoStat)
2.5" Pipes, No Cat, Flowmasters (Dual)
GT Grant Wheel, %5 Tint all around, 50% on windshield
--- Next Project ---
1992 Camaro z28 - 5.7ltr / Auto
6 speed swap, engine internals, turbocharge, SCCA!!!!
Old May 27, 2001 | 09:54 AM
Lostsol's Avatar
Howdy there, I don't have components in my dash but I do have an old set of Infinity Reference that is similar, with a 4" midrange and a tweet. All I can say is you'd probably have to build a pretty good bracket to make them fit, or possibly modify a stock one in some way. I'm sure it can be done though. I've also got a bass blocker inline between the speaker and power source. I think when I revise my stereo I'll stick with those in the dash and forgo the kick speakers for a while longer, till I decide just how good the sound quality is. Later man
Old May 27, 2001 | 11:16 AM
350iroc-z's Avatar
I put 4" speaker in the stock 4x6. I just made a custom plate that would hold the 4" using the stock 4x6 plate. Here are some pics of them.
http://www.350iroc-z.com/caraudio/4g.jpg
http://www.350iroc-z.com/miscpics/ca...dashplate2.jpg
Ryan
www.350iroc-z.com
Old May 28, 2001 | 01:12 AM
Car: too many ...
Right on!!! those custom plates look awesome!! what material are they made out of? thanks for the help guys!! if everything goes as planned, i hope to have 4" Boston components in the dash (tweets in the corners), 5 and 1/4" Boston component set in the kickpanels, and Boston 6x9's as the mids. gonna run everything with a 6 channel nakamichi amp 100x6 rms @ 2ohms. i know its kinda crazy to run 3 sets of speakers for the high's but i love my music!! k den thanks!!
Old May 30, 2001 | 02:14 AM
Kandied91z's Avatar
most major stereo stores that do installs will have brackets that will work for under $20 if you don't want to custom make anything and they will work just fine!
Old May 30, 2001 | 09:22 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
You can make those plates out of pretty much any material. I usually use wood because that's what I have lying around, but you can use ABS or even steel. If you want to, you can also offset the midrange toward the middle and you'll have room for the tweeter on that same plate. Just make sure that you'll have room in the dash to offset the mid. In 82-89 camaros it won't be much of a problem, but in firebirds and newer camaros modifications are usually necessary to accomodate larger speakers, especially if they bass driver is offset.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old May 31, 2001 | 05:11 PM
gobabygo's Avatar
i wouldn't bother with a component set in the front. just get a good pair of speakers; the tweeter is not necessary.
Old May 31, 2001 | 07:20 PM
Jim85IROC's Avatar
I disagree. For the most part, component systems tend to be of higher quality than coax speakers, especially the tweeter and the crossover. Obviously there are exceptions, but for the most part you have a much greater selection of better quality stuff when you use components. Any coax that is as good as a similar component set will cost as much too.
The IROC Homepage
Old Jun 1, 2001 | 09:12 AM
CloudIROCZ28's Avatar
That's pretty cool I wonder how big speaks I could put in there.....Would I be able to put 6 1/2's in there ????
1987 IROC-Z
G92, LB9 305 TPI, 3.23, Bright Red with Carmine Interior, Pioneer DEHP47DH CD deck.2 JBL DS645 4*6 (F).. 2 JBL DS965 6*9 (S).. Soon to get new 305 TPI
rocn7roc
Sep 21, 2021 02:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
The_Phoenix
Feb 4, 2016 07:10 AM
red90IROCls1
Aug 25, 2015 06:56 AM
NinjaNife
Aug 23, 2015 11:49 AM
