fm modulator, recommended?
Old Jun 2, 2001 | 06:54 PM
92 z28's Avatar
hey. i need help, and recommendations. i just installed a power acoustik cassette deck. i have a prestige 10 disc changer in the back. i was told the only way of having the cd changer run with this deck is by getting an fm rf modulator. now i was thinking, if i run the sound thru the antenna with a modulator wouldnt that sound like the radio? i know when i start pumping the sound pretty high in my car with the radio on you start hearing the static from the radio. will the same thing happen if i install the fm modulator?
is there any other way of connecting the deck and the cd changer than using a modulator? please reply. need the help.
dozer80464@aol.com
Old Jun 2, 2001 | 07:35 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
Does your cass. deck have any inputs on it for other devices? If not than you are limited on how you can do it. The FM modulator is about the only way to go. As far as clarity, it will sound a heck of a lot better than a radio station. It's a direct signal to the receiver in the cass deck, not coming through the air. It will be limited to how much frequency response you have. Most FM tuners in a car stereo cut off at 45-50hz. That is why so many radio stations boost their bass output in their format. So any cd that you play with really low bass, you may not hear that low bass because of the cut off in the tuner. Which should be OK though because 45hz is pretty low anyway. A bass drum is about 60hz, so any "real" music from real instruments will sound fine. It's rap or pop music that will have lower bass than that.
Old Jun 3, 2001 | 05:50 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Modulators sound decent, but not as good as a direct connection. But, you will need the modulator designed to operate that specific changer.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 4, 2001 | 11:30 AM
Mikes86SC's Avatar
Car: 1986 IROC-Z
Engine: 5.0 TPI
I have a Sony 10 cd changer hooked up through a modulator, and I have no complaints about the sound.
Maybe an explanation how they work will clear things up. Easiest is to think of it in the same manner as a cable converter box. The signal that comes into the converter is "converted" so that the program is sent to your TV on the same frequency as let's say channel 3. You set the TV to channel 3, change channels on the converter and voila! cable TV. Same for a video game. Your game travels through the cables on the same frequency as channel 3.
The FM modulator works the same way. Your incoming music is sent to your radio on a frequency of say 88.3 MHZ. You set your radio to 88.3 MHZ and through the antenna input it sees the music coming from the modulator. Since it is sent directly through a cable, you have no transmission/reception interference.
Hope this can clear things up.
Old Jun 4, 2001 | 06:37 PM
Chris Luongo's Avatar
Yes, an FM modulator would basically sound like the best FM radio station you've ever heard...pretty darn good, but still FM quality. Most people don't mind them too much, though.
Another option would be to buy a Prestige tape deck with CD changer controls...that is, if your Prestige changer will allow for a direct hookup.
Old Jun 4, 2001 | 07:41 PM
92 z28's Avatar
thanks all for your replies. i used to have a prestige deck, but the thing is, prestige doesnt make any decks with dancing spectrums, and thats mainly what i want. i decided to just buy a deck with a single cd player, what do you think?
F-body-fan
Jan 12, 2023 01:49 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Zell1luk
Sep 29, 2015 10:36 AM
dusterbd
Sep 29, 2015 08:40 AM
tattmann
Sep 27, 2015 05:20 PM
