Alpine and wiring harness
Old Jun 3, 2001 | 03:55 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The alpine and a harness to fit my 85 IROC don't exactly match up. The Alpine has an orange wire marked 'dimmer,' but the harness to fit my car has an orange wire marked 'illumination' and an orange-white wire marked dimmer. Do I disregard one? If so, which one?
JamesC
[This message has been edited by JamesC (edited June 03, 2001).]
Old Jun 3, 2001 | 05:19 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Wire the alpine wire to your "illumination" wire. When you turn your parking lights on, your deck will dim.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Jun 3, 2001 | 08:10 PM
JamesC's Avatar
And the orange-white wire? Tape it off and disregard?
Also, the orginal Delco, aside from the three plugs--blue, white, and black--has a separate two wire plug. One of the wires is orange (illumination apparently), the other brown. The aftermarket harness has the orange wire, but instead of brown, the second wire is yellow. Is this a problem?
JamesC
Old Jun 3, 2001 | 11:09 PM
Mista's Avatar
Car: 1986 Trans Am
Engine: 305 TPI peanut cam
the extra little harness.....
the yellow wire coming out of the new plug supplies 12v constant for the memory. Just connect it to the Yellow wire on the Alpine.
BTW your power antenna may not work. The Alpine I just put in, D852, doesn't have enough juice. The stereo shop gave me a relay and wiring instructions. I've yet to get to it.
86 T/A 5.0
93 Civic 1.6L
13.5 @ 100 mph
Old Jun 4, 2001 | 07:00 AM
JamesC's Avatar
Thanks for the heads-up--my Alpine is the 855. I'm going to be unhappy as hell if the power antenna doesn't function without modification.
JamesC
Old Jun 4, 2001 | 12:45 PM
JamesC's Avatar
Hey, Mista,
The power antenna works fine--by the way, I didn't have to modifify the Alpine's bezel to make it fit properly. Cool piece of equipment!
JamesC
Old Jun 4, 2001 | 02:09 PM
Jim85IROC's Avatar
Just out of curiosity, did you buy a wiring harness or are you doing a hack job?
The IROC Homepage
Old Jun 4, 2001 | 03:18 PM
JamesC's Avatar
I bought a harness. I appreciate your assistance--you too Mista.
JamesC
Old Jun 4, 2001 | 08:35 PM
Jim85IROC's Avatar
If you bought a harness, you should just be matching the colors of the harness to the colors on the Alpine deck. They should be a direct match, then the harness will just plug into the factory plugs and you'll have no screwing around to do.
The IROC Homepage
Old Jun 4, 2001 | 09:04 PM
JamesC's Avatar
Yep, with the exception of one wire, the orange-white, the Alpine and after-market harness matched up, and it was 'plug and play.'
JamesC
Old Jun 4, 2001 | 11:36 PM
Mista's Avatar
Car: 1986 Trans Am
Jim, any idea then why my Alpine 852 won't work my power antenna??? Not enough power????
I hear the ant. get power for about 1/4 sec. then nothing.
FYI Pink from factory harness goes into blue on adapter harness which is hooked to the blue wire from the HU.
86 T/A 5.0
93 Civic 1.6L
13.5 @ 100 mph
Old Jun 5, 2001 | 02:02 PM
Jim85IROC's Avatar
Mista, there might be something wrong with that radio. It should work fine.
The IROC Homepage
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
