What stock looking GM cd players could I use and which ones would I want?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The only ones worth a damn are the newer Delco units that have the speed-sensitive volume. Those are some great sounding, high quality decks. With a good Line Output Converter, they can be an integral part of a great sounding aftermarket system.
Any of the older Delco stuff is pure crap and should basically be avoided at all costs.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
"I didn't know a bored out Ford could go so slow" -Shenandoah
The IROC Homepage
Car: '88 Bright Red GTA UPC 81U
Engine: 5.7L TPI
Axle/Gears: 3.27:1
OOOOOOOOO, NOOOOOOO!!! LottaBalls, don't ask that. You'll get Jim all...... well, never mind.
Too late.....
P.S. - Jim, you know I love 'ya......
Frankie Rider, 2
The GTA Source Page
'88 GTA Red Hatchback - 5.7L/A4
'88 GTA Black Notchback - 5.7L/A4
'88 GTA Gunmetal Hatchback - 5.0L/A4
Too late.....
Frankie Rider, 2
The GTA Source Page
What year is your car? If it's '88 or older, you'll need to make up a harness and antenna adapter to get the newer decks to work...not a big deal though.
The first place to start looking is on eBay. Do a search for "Delco CD", "Pontiac CD," et cetera.
Remember, the Pontiac units light up red, which may or may not be what you want. Most of the other ones light up white. Just look for one that looks right in your car.
Since it will hardly make any difference in the price, you might as well get one that has the 5-band equalizer built-in.
A few of the units have a small, separate, outboard tape deck. If you play tapes, try to buy one of these units and come up with someplace to mount it.
Most Delco radios have the TheftLock feature. (If it's been turned on, you'll need to enter a secret code before the radio will work.) Be sure to ask the seller if the TheftLock has been activated, and if so, be sure to obtain the code from the seller.
ambainb
Apr 25, 2016 09:21 PM
Genopsyde
Oct 7, 2015 08:35 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
