power distribution blocks
Old Feb 8, 2002 | 02:24 PM
redcamaro83's Avatar
Car: 86 Z28
Axle/Gears: TBD
looking into fused pdbs
correct me if i'm wrong
Positive pdb should be fused
Negative PDB no need
some one told me that for a clean ground i should just
run a new cable to back of car with the same thickness as the positive
am i following the right path? i'm going to be removing interior soon to install new speaker wiring and sound deadening. Who can i buy RAAMAT from?
oh i found a company that has the factory speaker harness adapters.
adapters and harness adapter
tune town
Old Feb 8, 2002 | 08:14 PM
Belker's Avatar
The power distribution block should be fused.
The ground distribution block should not.
If fact, you don't really need a ground d-block (except for looks).
You SHOULD NOT run a ground to the front of the car.
The grounds should be as short as possible to extend to a good grounding point.
The grounds should be to the floor of the car and should be to clean, unpainted metal.
(The floor pan/chassis is a larger/better conductor than 0 guage wire.)
Old Feb 9, 2002 | 12:31 AM
Car: 86 Z28
Axle/Gears: TBD
thanx
where can i get raamat
Old Feb 9, 2002 | 11:26 PM
Belker's Avatar
get it at E-bay
I've heard.
Infested
May 22, 2018 11:56 PM
db057
Sep 4, 2015 07:57 AM
Brcharrelson
Aug 26, 2015 07:47 PM
pimprs
Aug 24, 2015 11:20 PM
sailtexas186548
Aug 24, 2015 10:11 PM
