Time display on radio...
I'm considering replacing (it died) the radio/tape player on my '88 GTA with either a cd/tape/radio or just cd/radio.
I DO NOT like the wild displays some sytems have. I would like the display to 'fit in' with the other GTA gauges.
I prefer 1 1/2 din size but will consider others.
I REALLY want the clock/time to be displayed all the time like regular GM radios.
Any suggestions?
jms
Any suggestions?
jms
Car: 1983 25th Anny Daytona 500 T/A
Engine: Stock...inoperative... 305
Transmission: Automatic
Re: Time display on radio...
Any suggestions?
jms
Any suggestions?
jms
https://www.thirdgen.org/techbb2/sho...threadid=81749
I'm pretty sure this is what I'll do as I don't care for all the wild displays either!
Rob
Thanks.
I saw that thread and if I remember correctly that swap was for a Camaro. Somewhere in there it was said it probably wouldn't fit a 'Bird.
jms
Thanks.
jms
My '83 has a console that is pretty similar to the Camaro.
Good luck!
Rob
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The radios mount the same way into the firebird as the Camaro. The only problem you'll have is that you'll have to cut away some of the heater duct passage and part of the plastic cross-piece at the back. It's probably easier to pull the center console out of the car to do it.
