How Stong Is Liquid Nails
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
It's great to use instead of "caulk" to seal the box. Just lay a bead on every joint before you screw the boards together. Even when your done, you can use it as a caulk to seal all the seams inside the box.
Just try and keep it off your fingers. The **** don't come off unless you clean your hands with gas/paint thinner right away. Otherwise, be prepared to use a razor blade to get it off.
tyeo098
Nov 30, 2015 06:27 PM
