some bose help
Car: 1995
Engine: 5.7
some bose help
i will be putting in new 6x9's and kickpanels. i took out the back lid (now theres four screws sticking out) and the wires are just siting there. when i put in my head unit which set of connectors are the power and antennae. i will only be useing those and run new wire to the speakers.
also how hard is it to run wire to the 6x9's and kickpanels.
First thing the 6x9's will clash with the kicks! The kicks balance out the sound stage(imaging) while the 6x9's in the rear are going to pull the stound stage to the right rear(for driver), and to the left rear(for passenger). I had this problem when I installed my kicks and it drove me nuts till I removed the rear fill altogether. I'd suggest don't even bother with running the wires to the rear unless you tend to have people that sit back there fairly often.
Please take a look at this post where someone else asked the same question.
https://www.thirdgen.org/techbb2/sho...ighlight=kicks
db057
Aug 11, 2015 10:11 PM
