Whats going on with my amp?
Old Jul 17, 2001 | 06:46 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
ive got a DHD power cruiser in the back of my firebird for my 12" sub (the lightning audio went back it crapped out) i was using it before... one day on the freeway the music was kinda loud, not really then boom, no more bass. went home turned off the car, now all it does is turn on for a sec, i hear about 1 sec worth of sub and it turns back off. i thought it was the remote turn on lead, i took it out and touched it to the terminal and it turns on for a sec, bass, then off. its mounted down in the well... i was running it bridged mono, its powering a mtx 12" 5000, 4 ohm svc. Any ideas? i have no more money for a WHILE..!
1989 Firebird
2.8 v6, t5 swapped in
Ram Hi-po clutch, Cold Air, 1.6 rockers,Lakewood LCA's, Lakewood Lift bars, Wonder Bar, 3" y-pipe, Random Tech Cat, 3" I-pipe, Flowmasters, MSd 6a, MSD Coil, Accel 8.8 wires, Auto Meter Gauges (Water, Clock, Fuel Pressure, and 5" Sport Comp Tach)TB Bypass, 4th Gen Seats
Coming for my v6:
Panhard Bar, 4thgen front seats, Nitrous, Line Lock, Posi, Spohn Torque Arm & Subframe connnectors
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
Old Jul 17, 2001 | 08:46 PM
btt
Old Jul 17, 2001 | 09:17 PM
Stoopalini's Avatar
Sounds like the amp is overloading for some reason.
First thing to try is:
disconnect the speaker leads from the amp, and turn it on. If the amp comes on and stays on, then try a different speaker.
If you still have the problem, disconnect the poewr/ground/remote wires from the amp and run a wire directly from the battery to both the +12 and the remote terminal. Then run a wire from the - on the bat to the - on the amp.
If still it won't turn on and stay on, then the amp is fried.
I don't know anything about that amp. Is there a switch to run bridged/mono mode? Or did you just hook up - on one side, and + on the other?
Also, is it stable down to a 2 Ohm load? Because that SVC 4Ohm woofer would present a 2 Ohm load to each channel in that config.
Good luck,
Thomas.
Old Jul 17, 2001 | 09:20 PM
ya its stable to 2 ohms..ok ill try that and ill post what happens
1989 Firebird
Coming for my v6:
#3 Forever
Old Jul 18, 2001 | 01:29 AM
ok..i disconnected the sub, and other speakers work with the amp... wtf?? ideas?? TIA!
1989 Firebird
Coming for my v6:
#3 Forever
Old Jul 18, 2001 | 03:48 AM
Jza's Avatar
Jza
there might be a short in the voice coil. or..once i saw one where a piece of metal (solder wire) had fallen and gotten lodged right across the two terminals (i've seen that twice actually, but the other time was on a starter relay).
try checking the resistance on the speaker. if it reads 00.00 there's an internal short and that's probably your problem.
Old Jul 18, 2001 | 08:56 AM
Stoopalini's Avatar
Jza is right on; either you have bad wires down to the speaker's terminals, or the speaker is toast.
I would remove the wires from the speaker terminals and solder new ones on; then test. If the speaker still won't play, it's time to replace it.
Thomas.
Old Jul 18, 2001 | 02:52 PM
Alright, thanks for your help guys!
1989 Firebird
Coming for my v6:
#3 Forever
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
