Why does my amp keep cutting out?
Old Aug 10, 2001 | 01:57 PM
AcSeb's Avatar
I put an amp in my car a couple of days ago after my other one was fried. It's a POS Majestic 200W that I have running my 6x9s and I'm trying to run my subs off of it also. The problem is when I turn it up....the amp starts to cut out. It's like it turns on and off when there isn't enough power to run the speakers. Some people tell me it's because there is no fuse from the battery to the amp itself and the amp is trying to take in too much power. I don't know if I can believe that. It usually runs OK if I've just got the 6x9s hooked in, one in each channel. But then I have my subs which I also would like to run on the same amp. When I hook them in though, the best way I can think to do it is to run the positive on one channel and the negative on the other channel along with my 6x9s. I'm probably wrong with this but it's the only way that I can think to do it. If anybody could tell me how I should be doing this or why my amp keeps cutting out when I turn it up a little bit I would greatly appreciate it. Thanks
Old Aug 10, 2001 | 02:42 PM
Polecat's Avatar
Running to low of on ohm load on the amp. If you continue to do that, you will eventually tear it up. You can run that two channel amp to the 6x9's, but get another for the subs.
MoJoe
Members Camaros
33
Feb 6, 2025 09:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
raymondandretti
Sep 27, 2015 06:43 PM
