Component system in place of 6x9s
Old Aug 11, 2001 | 10:40 AM
89Firebird Formula350's Avatar
Is it possible to replace the old 6x9s in an 89 firebird formula with a component system?
Thanks in advance!
Old Aug 11, 2001 | 12:50 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Yes it is possible. You will need to make an adapter plate to fit which ever size midrange you will get (6" or 5"). and then mound the tweeter above the mid.
I noticed you live in/near St. Louis, there is a Pro Audio stoe out be me in St. Charles that sells some very good component systems. CDT is my favorite and you can get a set with 6" mids for about $200 all the way up to about $400. If you're looking to spend less than that another brand, Memphis also makes very good speakers and are resonably priced.
Hope this helps,
Matt
Matt
1984 Camaro Z28
-'78 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM Air gap intake, ACCEL plugs & wires, 14" K&N filter.
-TH350 with Hurst Pro-matic shifter & B&M Street shift kit.
-Audiobahn single 12" Sub powered by Sony Xplode amp, Farenheit 6x9" & 4x6" speakers, with a Sony Xplode headunit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
Old Aug 11, 2001 | 01:24 PM
Mike92RS's Avatar
Yeah CDT's awesome! That's what I have all around. This is just a coaxial, but it's pretty much the same idea as a component set, you'd just have to mount a seperate tweeter. Just take out the metal piece that that the 6x9 screws into (it's held in with 4 7mm screws), and use it as a stencil for making a new plate with your choice of hole size(s).
- Mike
tglennon11
Sep 23, 2015 05:30 PM
64goatman
Sep 9, 2015 01:09 PM
scottmoyer
Sep 7, 2015 07:06 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
