Rockford sub/amp compatibility?
Old Aug 11, 2001 | 02:49 AM
DuffMan's Avatar
Car: '99 Cobra
Engine: 4.6 DOHC 32V
Transmission: T-45
Axle/Gears: 4.10
I was looking at getting a RF Power HX2 10" (1000 RMS/2000 Peak) and was wondering which amp would be better. Would the RF bd1000.1 be sufficient or would it work better with the RF bd1500.1? I was looking at the 1000.1, cuz I was afraid to blow up the sub with the power flowing from the 1500.1
Thanks a lot in advance guys!
Eric B.
Old Aug 11, 2001 | 01:27 PM
KlayBuRn's Avatar
i will be running a setup of 2 15' RF Power DVC's, 500RMS Dual voice coil subs(4 ohm a coil)...
i have a bd1000a1 for EACH speaker, im running them in parallel(?) off each other so that im creating a 2 ohm load on the amp which the bd1000a1 is rated 1000 RMS @ 2 ohms, other than 500 RMS @4 ohm...
i assume those HX's are 4 ohm DVC...
so yes, a single bd1000a1 should be enough to fully power that HX...
unless im on crack and dont know what im talking about
Old Aug 12, 2001 | 02:44 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Nope those current power HX2's are dual 2 ohm only, you can either get a 1500.1 and run it 4 ohm mono to pull 750w RMS, or get two 500.1's and run each on the 2 ohm coil giving you 1000w RMS.
SRKLEGIN
Oct 29, 2015 06:38 PM
tc7761
Aug 30, 2015 09:45 AM
STL1994
Car Audio
Feb 15, 2001 09:33 PM
Yellow Camaro
Car Audio
Nov 30, 2000 03:24 PM
imdamanbaby
Car Audio
Nov 29, 2000 03:51 PM
