Alpine stereo not coming on
Old Aug 17, 2001 | 08:06 PM
alivegy's Avatar
Ive had the alpine 7861 for 8 months and had it professionally installed. Last night when i turned my car on the stereo didnt come on with the car, i checked all the connections and they look good, but i cant find the fuse to see if its blown. The alpine manual says it has an inline fuse holder but i cnat find it and my 89rs doesnt have a fuse for the radio in the block. If one of the speaker wires was touching metal and shorting out would that cause it not to come on at all or something along those lines. Sorry for the long post im just dumbfounded, any help please?
Ryan
Old Aug 17, 2001 | 09:44 PM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
Have you checked the back of the stereo?
On some car stereos they put a fuse in the back of the unit and a inline fuse as well.
You'll have to pull out the unit to see if a fuse is back there.
As for a inline fuse.....
Fine the red wire on the unit and follow it until it ends.
THen you will find out two things.
1) the inline fuse (looks kinda like this..... ----(FUSE)----- ) It's a small plastic pieces usually white/clear or black.
2) where the power goes to your fuse block.
Hope it helps.
Old Aug 18, 2001 | 12:18 AM
alivegy's Avatar
It doesnt have the fuse in the back, i checked that first, i also know it doesnt have a fuse in the fuse box, but where does the power cbale originate from and where is it grounded too? All the cables just lead up and behind the thermostat.
Old Aug 18, 2001 | 06:50 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
You should have a fuse for your radio in the box under the dash on the driver's side. My '84 Z has one for the int. lights and radio. If yours is the same and your dome light works than it is not the fuse. Then make sure the radio(AND ANTENNA!) are grounded properly. If the antenna is not grounded that may cause the radio to not come on.
If those are not the problems then you need to check that both power wires (switched & continuous) are connected right. Also if it will accept and eject CD's then your continuous power supply if ok.
Hope this helps,
Matt
Matt
1984 Camaro Z28 - Black w/ Grey int.
Best 1/4 - 13.6 (5-speed) & 14.0 (Auto & 2.73!)
-'78 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM Air gap intake, ACCEL plugs & wires, 14" Accel filter, Homemade Cold Air Indctn.
-TH350 with Hurst Pro-matic shifter & B&M Street shift kit.
-Audiobahn single 12" Sub powered by Sony Xplode amp, Farenheit 6x9" & 4x6" speakers, with a Sony Xplode headunit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
Comming Soon:
3.73's, Flowmaster, hollowed cat. & Paint: Navy Blue Metallic w/ Silver strips
Old Aug 18, 2001 | 11:02 PM
Graeme'sFirebird's Avatar
From: First one out of liberty city, burn it to the ground
Theres another fuse..same thing happened to my radio, the clock worked but it didnt come on. Under the dash, there will be a black square with tabs on it, above that are some more fuses including one for the radio..check that.
Slowly getting slower 1989 Firebird.. modded heavily for a v6
"I'd rather run last in a full out race, than to NOT have run at all"
#3 Forever
My Site:
Click Here to see my car!
kairles
Oct 26, 2015 09:13 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
tc7761
Aug 30, 2015 09:45 AM
Cripley
Aug 17, 2015 03:35 PM
