SUBS ARE IN FINALLY!!!!!! STILL GOT QUESTIONS!!!!!!!
Old Aug 8, 2001 | 12:11 AM
CD MaroMan 91's Avatar
I only have the Rockford Fosgate 100.2 amp. It still hits great!!! Sounds awesome. Now... what can I used to keep the license plate from rattling? Also when I turn the volume up and put in some cd's with good bass the front of my car seems to vibrate a lil bit. Like a rattle but I dont' knwo where. Also should I get dynomat? If so how much and where should I put it. Anything else on getting rid of rattling??? Thanks in Advance!
(orignally CDnAP48)
'91 Camaro RS (in readers rides)
Dark Metallic Blue
V6, 4th Gen Seats, Sony Xplod CD Player and Sony Xplod 6x9's, Kelly Charger Front Tires. Soon to come, DJSexay Kick Panels, Polk Audio Component Set, 2 Rockford Fosgate 12"
s, Rockford Fosgate Amp, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
E-mail me for any questions or comments.
AdidasPredator15@jam.rr.com
http://www.geocities.com/adidaspredator21/index.html
Old Aug 8, 2001 | 05:44 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Some weather stripping or such in the right places will stop the license plate from rattling.
Old Aug 8, 2001 | 08:48 AM
REZN8R's Avatar
Car: '96 M3
Engine: 3.2L V-6
Transmission: 5-sp
Or some sticky back foam between the license plate & plate frame. You didn't screw that amp down through your gas tank did you?
Old Aug 8, 2001 | 11:45 AM
sunbitz's Avatar
Car: 91 RS Convertible
Engine: 305 TBI
To help find those rattles......
Turn down all your mids and highs and pop in a very bass CD.
Then all you will hear are bass and rattles. If you have a amp hooked up to the rest of your speakers then shut that amp off and use only the bass amp and you'll find those rattles.
I agree with the 2 sided sticky foam idea. I used velcro on my plate in the rear and it worked pretty good, but my sub don't hit as hard as yours do. I only have a single 12" in the back.
One thought....
Take 2 pieces of 2 sided sticky foam tape.
Apply one piece to the frame and then apply some fabric ontop of that.
Then take the other piece and apply it to the plate along with some fabric.
Now you have no rattle and you can still get that plate off when needed without having to pry it off.
Only thing is that it may not hold up too long after washing the car.
You could replace the fabric with some saran wrap type material to protect the glue from water.
Again just a thought.
Old Aug 8, 2001 | 10:11 PM
OK guys... thanks for the suggestions... First off as far as I know I didn't screw into the tank. I thought about not mounting it there because I read about that but someone else told me the gas tank was farther down than that. My screws that came with the amp were really short. I don't even think they went through the metal because I can grab the amp and pull up and the carpet comes up a lil bit with the amp so it's not attached.... my mom has some double sided mounting tape. I'm gonna try that with the license plate tonite... Also, does anyone know how to keep the 3rd brake light cover from rattling? mine rattles like crazy... maybe my screws are loose back there so I'm gonna tighten those up in a lil while too....
(orignally CDnAP48)
Dark Metallic Blue
Old Aug 9, 2001 | 12:13 AM
MADOGIROC's Avatar
I bought dynomat specifically for my license plate. Still some raddles but hardly noticeable.
Old Aug 9, 2001 | 10:35 AM
mcconahay37's Avatar
To mount my amp, I bought some velcro from the automotive section of Wal-Mart. It's the kind that has a sticky side and you peel off the film to uncover the sticky stuf. Works great. My amp hasn't moved on me yet and that is with a lot of autocrossing.
82 Camaro:
350
Erson cam, ported heads,Comp Cams 1.6:1 rocker arms
Edelbrock Performer RPM intake, Holley 600
Crane Hi-6 ignition, Accel supercoil
TH350 tranny with 2500 stall.
Eibach Pro Kit
SLP 1 3/4" headers
Old Aug 14, 2001 | 04:14 AM
305camaro85's Avatar
about the license plate rattling, dynamat offers a license plate kit that stops the rattles. It is only like 13 bucks and i got one and my license plate rattles are gone. They work great....
Old Aug 14, 2001 | 01:32 PM
Nick89TA's Avatar
For the plates, I used some 1/8" or so thick single sided foam weatherstrip tape under the frame. It worked great!
Old Aug 14, 2001 | 06:45 PM
haha that's exactly what i used... it's double sided mounting tape.. it's white and foamy but it worked!
(orignally CDnAP48)
Dark Metallic Blue
V6, 4th Gen Seats, Sony Xplod CD Player and Sony Xplod 6x9's, 2 RF Punch 12's, RF Punch Amp, Custom Made Black Carpeted Box, Kelly Charger Front Tires. Soon to come, New Rims, New Rear Tires, Carpet, Floor Mats, Paint Job, Interior Color Change.
Old Aug 18, 2001 | 11:26 PM
85ws6TA's Avatar
Car: '92 Typhoon/ '79 Vette
Engine: Turbo 4.3L/Forged 355ci
Transmission: 4l60/th350
for the amps and eq in the back of my TA, i pulled up the carpet, and saw the original color which was beautiful..., and mounted down some 3/4" particle board. then i put the carpet over that and screwed my equipment to it. looked great, i wish i had pics. and its actually alot easier than it sounds. i set aside about 5hours on my day off to do it and it took me a total of about 1 1/2 - 2 including install to deck and running the wire back.
Old Aug 19, 2001 | 09:28 AM
Dark_Boba's Avatar
Save a lot of MONEY and get this stuff at www.b-quiet.com
Frozer!!!
Jan 19, 2024 04:55 PM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
aaron7
Aug 17, 2016 06:02 PM
Polo Z03
Sep 10, 2015 06:43 PM
redmaroz
Aug 16, 2015 11:40 PM
