What kind of 4x6 would you recommend?
Old Feb 20, 2002 | 03:37 PM
V8_Proud's Avatar
Hello
I'm just slowly putting my stereo together
so far I have
Pioneer 1300 deck (45x4)
Kenwood 6x9 at 170w
Kicker 100psi amplifier
2x12" Clarion at 500W max I believe
stock 4x6
any 4x6 you would recommend on this list?
http://www.cardiscountstereos.com/Sp...ub_Catagory=46
Also, should I get tweeters to go with the front 4x6, even if the most new 4x6 have a built in 1" tweeter?
Thank You
Old Feb 20, 2002 | 04:01 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Ah, heck if I know ... I just ordered a pair of the Pioneer TS-G4647's .... price is decent and have to sound better than the stock POS's .... I'm pretty sure they're not the best ones out there, but I haven't had any problems with Pioneers so far ... I'm running a pair in the rear right now that are a few years old.
Old Feb 20, 2002 | 07:31 PM
xxwarrior36xx's Avatar
I love my cerwin vegas, and they also are pretty cheap. My friend has pioneers and he has no bass out of them. He also complains about them distorting very easy. I have had no probs with mine and man there loud. I thik they are a buy for the money
Old Feb 20, 2002 | 07:56 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
No need for bass out of 4 x 6's ... especially when you have a couple o' 10's in the back ... my bass **** sees the midway point at best
Old Feb 20, 2002 | 09:24 PM
IROCET's Avatar
Car: 88 IROC-Z (Sold)
Engine: 5.7L
In my opinion, forget about the 4x6 idea and do one of two things. Look into component speakers for the kick panels or get a 4x6 plate system with a round speaker and a tweeter instead of the oval speaker.
The component setup is going to be more difficult to do, just b/c of the fact that you either have to buy or make kick panels for them. Though that is not hard, it is more time consuming than just stuffing something in a pre-made hole in the dash.
The 4x6 plate setup is going to give you much better sound than a 4x6 will. A round speaker is better for bass than an oval speaker, which distorts easier b/c of the shape of the cone. Boston Acoustics makes a nice 4x6 plate setup, which you can view at this link: http://www.bostonacoustics.com/Serie...ID=26&SpecID=4 I know Infinity used to make one, but I don't know if they do anymore or not. The plate setups can usually handle more power than the standard 4x6 also. In the case of the Boston Acoustics, it is 40 more watts, plus it is the middle of the line speaker instead of being bottom of the line like the 4x6.
If you have never looked at Boston Acoustics speakers, I highly suggest you check them out. They make some of the best speakers on the market (in my opinion). You see them in home audio alot now also. The Pro line of car speakers is phenominal. Good luck.
Matt
Old Feb 21, 2002 | 04:51 PM
Fade00's Avatar
I put some Alpine 4x6's in my dash. They are actually too deep for the dash, but not by much. Once I put the speaker covers on you cant even tell.
They sound crystal clear as well.
Old Feb 21, 2002 | 06:32 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Come on guys read the post. He already has Kenwood 6x9's. Stick with one kind of speaker in your car, subs can and usually are differant brands than the full range speakers, but full range speakers MUST be the same. If not the speakers signiture won't match leaving the soundstage confusing. In audio, selecting differant types of speakers is like putting differant size wheels and tires on your car. You don't want 15's on the drivers side and 16's on the other do you? If you want differant front speakers then get differant back speakers.
As far as what's best...the possibilities are endless. I'd just get a Kenwood 4x6 plate set if they sell one. Plates usually sound better than oval speakers becouse they have a devoted midbass and a tweeter mounted to the inside, not only does this keep midbass from being deflected, but the round cone won't flex as much as an oval cone. Plus I've heard these fit much better, with the shallower mounting depth on the tweeter side and off center mid magnet, making it easier to fit in some Firebirds that may have ducting in the way.
Good luck,
Matt
Old Feb 21, 2002 | 07:30 PM
87transam5.7tpi's Avatar
one word: KICKPANELS I was in the same boat as you, its way worth it
Old Feb 21, 2002 | 09:20 PM
1sweet89rs's Avatar
i have a set of pioneer 4x6 plates which sound awesome,but if you want to stick with kenwood i used to have a set of kenwood excelon 4x6s up front which also sounded pretty good but couldnt handle the power i had into them(bout 75 watts)but they where probably the best 4x6 i have ever heard (and i think ive heard them all)
pioneer deh6400 head unit,XM radio,rockford fosgate 400x4 powering pioneer 4x6 plates and pioneer 6x9s,rockford 600x4 powering 2 audiobahn 10s
Old Feb 21, 2002 | 11:21 PM
85maro's Avatar
I have sound storm 4x6's, they sound really good for the price i paid for them.
Tim
Old Feb 21, 2002 | 11:32 PM
By the way Allan I have substoo...and there is no such thing as too much bass. You have to like it when you feel the bass in your steering wheel form your 4x6's. Thats just me though
Old Feb 21, 2002 | 11:33 PM
Night Hawk's Avatar
INFINITY KAPPA 4 X 6 PLATES!
I have them and they rock! Discover instruments being played in the background that you couldn't hear before!
Old Feb 22, 2002 | 11:28 AM
V8_Proud's Avatar
Absolutely
thanks for all the advice
PS>
What do you think of this?
AudioBahn 4x6
http://www.cardiscountstereos.com/Ca...uct+%23=AS64PC
and
Power Acoustik 4x6
http://www.cardiscountstereos.com/Ca...t+%23=XP2K465P
Old Feb 22, 2002 | 02:31 PM
berlinetta305's Avatar
anything EXCEPT rockford audio - I blew 2 pairs in 1 week!!
Old Feb 26, 2002 | 08:23 AM
Four12'sCamaro's Avatar
I have Audiobahn 4x6's and the are the plates so there are the component style with xovers that i mounted on the kick panels with tucked wires. I love the Audiobahns and they were cheep off of uBid.com.
Peace
Old Feb 26, 2002 | 12:26 PM
jobryan26's Avatar
The Kenwoods don't sound too bad but power, Notta! I had the Excelons and the Infinitys. IMO the Infinity's smoked'em pretty bad in SQ. Best route is plates if you have a Camaro or like to hack up the dash in ole Firebird. I'd skip the hard work and the waste of money because even with plates there is very little midbass and the imaging sucks. So skip all that and get you some Kicks or make your own and be happy. That way you will have good midbass, imaging, and with components or a larger speaker like like what 87transam5.7tpi has (1 Coaxial in a the kicks) you can throw alot more power to them and increase the front sound stage.
Old Feb 26, 2002 | 01:11 PM
ya my kicks helped alot!! I'm never going without em again :-) if you want some pics or how I did it let me know. I'm working on a tutorial on my site, should be up in a week or so. take it easy
Josh
Old Feb 26, 2002 | 02:07 PM
CamaroZ_85's Avatar
If you are intersted, I have 2 curent auctions for 4x6's, one is a pair of kenwoods that i bought first. then i moved up to the eclipse's (these sounded better IMO) before I went to kicks. check them out if you'd like.
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1335432578
http://cgi.ebay.com/aw-cgi/eBayISAPI...tem=1335451406
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
drumstixer
Sep 29, 2015 03:02 PM
Zell1luk
Sep 29, 2015 10:36 AM
kitt23
Sep 26, 2015 07:48 PM
