Putting 90 GM Head unit into 89 Forebird
Old Feb 20, 2002 | 04:11 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I'm putting my 1990 Lumina unit in my 89 firebird and I have one problem. Everything fits and works good but when i turn my lights on the station light dims but no lights on the radio come on like station and so on. Am I missing something?
Old Feb 28, 2002 | 11:58 PM
custm1992's Avatar
your 90 Lumina deck doesn't have an illunination input, therefore no light
Old Mar 1, 2002 | 01:01 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
how do i get it to light up then? when it was in the lumina it lit up.
Old Mar 1, 2002 | 10:25 PM
custm1992's Avatar
does anything light up at all??? or is it just the dimmer???
Old Mar 2, 2002 | 12:05 AM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
in the lumina everthing lit up, when in the firebird only the clock /station dims.
Old Mar 2, 2002 | 10:28 AM
custm1992's Avatar
try comparing the factory wire colors between both cars, they should be exactly the same. I'm guessing that the 'bird doesn't have an illumination wire in the car period. for some help here are the factory wire colors :
tan - front left positive
gray - front left negative
lt. green - front right positive
dk. green - front right negative
brown - rear left positive
yellow - rear right negative
dk. blue - rear right positive
lt. blue - rear right negative
orange - +12v constant power
yellow - +12v ignition power
black / dk. brown - ground
pink - power antenna turn-on
any other wires will be connected to the illumination of the car. be careful because some cars require a negative illumination and some require a positive.
Old Mar 2, 2002 | 02:23 PM
Grants85TA's Avatar
I had the same problem with an 89 grand am deck in my 85 ta.
Just needed to replace the bulbs. hope this helps.
Jake_92RS
Jan 28, 2020 10:37 PM
gta90
Sep 15, 2015 04:00 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
86White_T/A305
Aug 17, 2015 12:16 AM
ZsTransAm
Aug 11, 2015 07:30 PM
