An entire system wired with cat 5?
Old Aug 20, 2001 | 10:52 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Ive seen something posted here before about suplementing RCA with cat 5 cable but I cant find it.
I have access to a TON of the stuff! I was thinking about running cat 5 to the rear speakers and possibly running some back to the sub so I can relocate the amp onto the box "suplementing cat 5 as RCA" any problems with this??
Thanks SSC
Old Aug 20, 2001 | 10:59 AM
kurgen's Avatar
why? other than cat 5 is dirt cheap (free if your a net work tech.) any adapters/modifications would makethe cost about the same.
just my 2 cents though
Like Car Audio?
check it out:
www.loudride.f2s.com
Old Aug 20, 2001 | 12:19 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
<font face="Verdana, Arial" size="2">Originally posted by kurgen:
</font>
I am a CCNA & Novel certified tech
Everything computer related is free to me
Ok enough bragging.
I am considering this only because I want to relocate the amp and I dont want to spend 80$ on a good pair of RCA cables cat 5 should be just as good or better. I have had bad luck with cheap wallmart RCA's and cant justify 80$ for the boom factor.
I dont know Im at work and bored.
SSC
Old Aug 20, 2001 | 01:21 PM
GndPrx's Avatar
You don't have to spend $80/set for RCA...that's just getting ripped....
I just picked up 4 sets of Stinger Bullet series 17' 2 channel cables for $20/set and I know you can get them anywhere from $20-$25/set online.
If you can still find anyone with a stock of street wires cables left you can get ZN2.0's for around the same price as well and even though I'm not a Monster Cable fan at all, you an get XLN's for $20-30/set as well...
As far as Cat5, yes you can use it and probably get away with it. There are many people successfuly running cat5 as their signal cable, but there are just as many who failed...it depends on the vehicle and the quality of the solder job that you do.
So I'm not really sure who gave you a line about having to spend $80/set for RCA cable, but I'd look around some more before resorting to cat5.
Carl
CarAudio Resources
[This message has been edited by GndPrx (edited August 20, 2001).]
Old Aug 20, 2001 | 01:46 PM
350iroc-z's Avatar
Just my thoughts but...
Even if you used shielded twisted pair, it wouldnt have the same type of insulation as a high standard rca to protect the wire from picking up outside noise.
I could be wrong but like i said its just my thoughts :-D
www.350iroc-z.com
Old Aug 20, 2001 | 07:38 PM
Omar's Avatar
<font face="Verdana, Arial" size="2">Originally posted by 350iroc-z:
</font>
The opposite is actually the truth. You dont want a shielded wire, as it acts as an antenna for noise. You want UTP, or unshielded twisted pair. Major companies such as Monster Cable all make their RCA cables as UTP.
1989 IROC-Z 5.7L
NOS 5151 150HP kit
ProBuilt 700R4, PI Vigilante 2800 stall lockup
Baer Brakes 12" Sport System
Old Aug 20, 2001 | 07:50 PM
HrdRockA4305's Avatar
It sounds like a good idea to me. Cat 5 UTP is super cheap (the company i work for happens do be a Belden distributor amongst many other cool things) and the pair twisting along with lack of sheilding should be nice and quiet. And if it dosen't work out, whats the big loss? You could always just say screw it and used RCAs if it dosen't turn out so good. Lemmie know how it turns out if you do it.
88 Camaro (The mighty LO3 SC!)
305TBI/700R4/2.73/122,XXX miles
14" Open Element and Flowmaster 80 seires
Next up: headers and gears
Old Aug 20, 2001 | 08:26 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
The 8ft rca I bought for my truck was 35/40$ I forget what brand but its purple. So with a stealth install route it where it fits and cannot be seen I figure 16ft, 8ft around 40$ so I assume 16 would be almost 80$. I have used lesser quality cables and have always ran into static problems. Heck I'll just try some UTP, STP or console cable I like the flat console cable cause I could run under the carpet with no bumps showing.
If it works I'll let you all know in a few days.
Thanks for the relpies!
SSC
Old Aug 22, 2001 | 02:09 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Remeber though that CAT5 TP has very thin wires. Most good RCAs use a large gauge wire. I think my expensive Phoenix Gold RCAs were 12 guage.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 5/30/01)
There can be only one!!
Vintageracer
Jan 10, 2020 05:33 PM
midge54
Dec 27, 2019 04:14 PM
Infested
May 22, 2018 11:56 PM
Caspar
Jun 19, 2016 11:19 PM
