Update kicks part 1...
Old Aug 25, 2001 | 07:03 PM
GndPrx's Avatar
Well, now that I've ditched about everything that I was working on for the bird, at least I've started working on the final revision of the kicks...
Right now they are just raw fiberglass. Once I finish the mold for the 8's I'll carpet it all in matching charcoal so they blend in when the grills are on.
I'll update more as I add the portion for the 8's and the horns under the dash...
More another day...
Carl
CarAudio Resources
[This message has been edited by GndPrx (edited August 25, 2001).]
Old Aug 26, 2001 | 01:12 AM
jobryan26's Avatar
Did you say 8's in the kicks? ImageDynamics?
See my Ride:
https://www.thirdgen.org/rides/index...ew&rideid=1324
Old Aug 26, 2001 | 07:28 AM
GndPrx's Avatar
Yes and Yes...
The R&D person over at ID is my old installer and he and I have been working on the front stage design.
Basically 8's setup with AP mats.
Carl
CarAudio Resources
Old Aug 26, 2001 | 10:39 AM
DJSexay's Avatar
looks good. Did you just build up off the stock plastic pieces ?
mike
custom 3rd gen kickpanels at
http://www.lachernet.com/kickpanels
Old Aug 26, 2001 | 10:59 AM
GndPrx's Avatar
Mike,
I used the stock plastic as a mold. Just used some PVA and laid right over the top of it to make a duplicate. The stock pieces are sitting off to the side for future use if I need them.
Belive it or not, the "body" of the kicks was made off of a rewritable cd spindle cover. I just cut it to the heigh and angle that I needed and used it as a mold for a fiberglass ring that was positioned exactly the way I wanted. Added my baffle to that, wraped a wring of 1/8" hardboard around the baffle for the inser for the grill and streatched an old t-shirt and 2 layers of mat for the rest. I'm thinking I'll have to remember that cd spindle trick down the road as it worked out rather well.
Here's the ring for the 8's to give you an idea of how they'll sit.
Carl
CarAudio Resources
Old Aug 26, 2001 | 11:27 AM
JPrevost's Avatar
Car: 91 Red Sled
I think I might be a little confused by those last pictures. Are you installing 6.5" in the kicks and 8s behind them? The pictures look like you will have ZERO foot room and is the brake pedal going to go down all the way? Why not install the 8s in the door panel?
, Jon (350 TBI!)
91 Red My website
Old Aug 26, 2001 | 12:49 PM
GndPrx's Avatar
5 1/4's in the kicks and 8's behind them.
They will essentially be sunk into the floor with a small enclosure with AP mats built outside the car (partially in the wheel well).
Even if I were to leave them as they look in that picture, I would still have about 3" of clearance behind the break pedal when it was depressed all the way, so clearance is no concern.
Once it is all in place and carpeted over, you should only see the grill for the 8 and loose less than 1-2" of leg room...keep in mind that those pics were just to show rough positioning.
Above both of those tucked back as far as they will go will be a set of horns.
Carl
CarAudio Resources
Old Aug 26, 2001 | 04:47 PM
Tyler-88's Avatar
wow.
thats one hell of an interesting concept. i would imagine that an 8" would kill the sound from a 5.25" i think youd be a very popular guy if you made some for a 6.5 and a tweet.
Old Aug 26, 2001 | 05:06 PM
GndPrx's Avatar
Wouldn't take much to adapt these to seperates, but that's DJSexy's domain and I'll leave it to him to sell the kicks. I don't have enough time to produce any for sale anyway...I'm lucky I get time to work in my own car.
Carl
CarAudio Resources
Jake_92RS
Jan 28, 2020 10:37 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
armybyrd
Aug 17, 2015 08:59 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
