umm..... My Mb Quarts are on fire....????!
Old Sep 10, 2001 | 09:47 AM
FiReBReTHa's Avatar
ok, well, with my car, and now my car audiolikes fire.
i got the jl audio300/4, powering four mbquart PSD 216 6.5 comp set.
if you guys know about quart, inside the crossover there is a fuse, now when cranking the music. it will stay clear, And the fuse Will GLOW.
no more fire.....
dont like fire in my car audio...
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Old Sep 10, 2001 | 10:12 AM
Mike92RS's Avatar
It it a normal fuse that's glowing? I've heard of crossovers that have a light-bulb kind of deal, so as the power increases, the bulb will start to glow and will add resistance, lowering the power going to the speaker to prevent overpowering them. That could be the case.
- Mike
Old Sep 10, 2001 | 03:46 PM
FiReBReTHa's Avatar
it does glow with the intensity.......
hmm.....
this is intresting... thnx.
any other thoughts guys?
Old Sep 10, 2001 | 03:54 PM
85transamtpi's Avatar
I know that in some proaudio speakers that I have used for live shows they use something like what you are describing in the crossover for the horn. In my experience with these the more power you give them the more they glow. You seem like you have plenty of power so that would explain it.
peace
Old Sep 10, 2001 | 08:35 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Many crossover units wire a light as a tweeter protection. When you start cranking it, it looks like lightning in a dark car.
The IROC Homepage
<A HREF="http://www.rit.edu/~jli4307/camaro" TARGET=_blank>
View the restoration of an 85 IROC</A>
Custom Thirdgen Subwoofer Enclosures
"I didn't know a bored out Ford could go so slow" -Shenandoah
Old Sep 10, 2001 | 09:32 PM
FiReBReTHa's Avatar
hey jim,
not lightning more like
"I SEE THE LIGHT! AND IT BLINDS ME!!!!!!!!"
Old Sep 11, 2001 | 01:34 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
OK, your "fuse" in the crossovers is actually a light bulb even though it look like a fuse, it is for the tweeter protection circuit as described above... too much power for the tweeter the light glows / flashes to protect them .... I would recommed re adjusting your amp gains so that at "full volume" the lights are just starting to come on or eventually you will fry your tweets, besides with the tweeter level at 0 db isn't there plenty of "tweeter highs" on my PSC 316 set (6"4"1") with the RTC 25 mm (1") tweeter they WAIL at almost any volume and I have the X-overs set to -3 db and also my EQ set at -2 DB at 16 KHZ to smooth out the top end Anyway hope this helps,.. DAVE
1967 Camaro RS w/ 454 restoration in progress.
1982 Camaro Z28 MANY mods and someday some HP
MECP certified car audio installer
SCCA autox ESP class #28
Hotrodboba400
Dec 10, 2019 07:07 PM
abray1
Sep 14, 2015 08:18 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Navy8125
Aug 17, 2015 01:29 PM
