impediance adapter
Old Feb 25, 2002 | 04:12 PM
89formula#1's Avatar
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
impediance adapter
hey guys i have 2 of these things called HI/LOW impediance adapters. they wire into your harness and lets u run RCA's so you can hook up an amp. my question is they are adjustable and i dunno wut they do wut effect would adjusting the impediance have on the sound? I am gonna run these to am amp then to my 6x9's. also my head unit is 45wx4 and my 6.9's are 200w. the amp i have is a 100 watt amp would this sound alot better through the amp them through the headunit. thanks
Old Feb 25, 2002 | 07:16 PM
CODY BEHNKE's Avatar
Are you refering to a down converter? It is for turning a high signal into a low signal for amps with no high signal input. Only the cheap ones are adjustable. If you use a down converter get a good one. None are better than a set of low out RCA's though
Old Feb 26, 2002 | 12:10 AM
Belker's Avatar
LOC = Line Output Converter = High Level (speaker wire) -> Low level (rca patch cord)
This may be what you have?
InfernalVortex
Apr 20, 2021 11:31 AM
Twin_Turbo
Mar 14, 2016 10:10 PM
dusterbd
Sep 29, 2015 08:40 AM
dbrochard
Wheels and Tires
Sep 25, 2015 05:40 PM
romcjr
Sep 17, 2015 05:18 PM
