Woofer humming
Old Sep 12, 2001 | 05:48 PM
Abe65's Avatar
Woofer humming
i just installed a new radio in my camaro and now the two twelves I have will consistently humm almost to the engines rpms. Could this be a grounding problem?
Old Sep 12, 2001 | 06:25 PM
Chevy83Z28's Avatar
Several things to check. Not sure about which order to check it though.
It could be the crossover on the amp isn't set low enough, it could be incorrectly set gains on the amp too. I'd try to re-ground the amp to another spot, see if that helps, also try another pair of RCA cables. Usually the static/noise only comes through on speakers, not really subs... or at least I thought so. Either way, good luck.
Old Sep 12, 2001 | 06:56 PM
JPrevost's Avatar
Car: 91 Red Sled
Sounds like somebody ran his RCA cables next to a power line! A ground problem wouldn't cause the whine, it's a problem with your signal wires going to the amp, they're either really thin or running with a power wire for a foot or more.
, Jon (350 TBI!)
91 Red My website
db057
Jan 10, 2020 08:55 PM
305IrocZ28
Car Audio
Oct 22, 2001 08:58 PM
92 z28
Car Audio
Jul 7, 2001 01:19 PM
Christos
Car Audio
Jul 6, 2001 03:42 PM
