Sub making scratchy/buzzing sound..
Old Oct 2, 2001 | 08:24 PM
SLAYER6669's Avatar
Car: 1991 Camaro Z28
Transmission: T56 6-Speed
Well the topic says it all.. One of my subs blew a while ago and I'm running the one subwoofer for now until I get the other one back.. I noticed that its making this buzzing and or vibrating sound that I can only hear when the volume is lower of course.. Is it possible this sub could be damaged since the other one blew? I don't know what else it could be.. the subwoofer sounds fine at higher volumes.. thanks
1991 Camaro Z28
CURRENT MODS:
350 TPI, T56 6-Speed, Edelbrock Headers, Edelbrock Runners, Edelbrock Intake, Flowmaster Exhaust w/ Flowtech Cutout, MSD 8.5mm wires, Autolite Double Platinum Plugs, MSD Cap/Rotar, Random Technology high flow cat, Hypertech Power Chip (160 Deg Thermo), K&N Filterchargers
STEREO MODS:
Pioneer DEH-P6000, 2 JL Audio 12W3 subwoofers in custom hatch enclosure,
Rockford BD1000.1 Amp, Infinity Kappa 4x6" plates & 6x9's
WEBMASTER: www.thirdgenfbodies.com
[This message has been edited by SLAYER6669 (edited October 02, 2001).]
Old Oct 7, 2001 | 04:45 AM
IROCketZ28's Avatar
I'm surprised to see a W3 blow off a single BD1000. I've seen many hold up fine to a D2 or a 2000X. Do you have your gain turned up a bit too far? Pushing the amp into clipping and sending square waves to the subs will eat the subs quickly. If this is the case, the second sub might be on its last legs.
You didn't mention if the noise is more noticable with the engine running. If it is, check for anyplace that may introduce engine noise into the system...RCAs ran too close to your power wires, a ground that may have vibrated loose, a bad RCA, etc. Try regrounding the BD in a different spot and see if that makes any difference. Also, with this much power, you should have upgraded your batt. to chassis ground to at least 4-Ga, rather than the factory 8-Ga. Hope this helps out a little!
'87 IROC Z28
SS 1-2 in dB Drag, Stk2 in IASCA IdBL
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
AFPR (set @ 46 lb)
TB AirFoil
Grant wheel
Custom short-throw shifter with leather boot
Pyle head-unit, Audio Control Epic-150 (Epicenter, SPL meter & voltage meter), Audiobahn 16V line driver, Autotek 4x100 mid/high amp, (2) Earthquake PH-D2 amps, (2) Shocker Audio 12" Shocker Xtremes w/ dual 1-Ohm coils in a 6.6 cu ft 4th order enclosure tuned to 45 Hz for SPL, 33 Hz for street. Polk/Eclipse front stage. Roughly 4500 W RMS. Good for 152.1 dB so far, shooting for 155 by the start of next season!
Check out my homepage and let me know what you think!
http://hometown.aol.com/ldaly33569/m...e/profile.html
IROCketZ28@caraudioclub.net
[This message has been edited by IROCketZ28 (edited October 07, 2001).]
Old Oct 7, 2001 | 10:26 AM
SLAYER6669's Avatar
Your reaction to the subwoofer blowing is pretty much the same as everyone elses, the gain was a little more than halfway up, and the punch bass was almost 3/4 as well, I was playing a CD with ALOT of bass at the time it blew.. I will actually have to double check the RCA's behind the headunit maybe it got pulled out a little bit while I was reinstalling it.. As for the wiring, i HIGHLY doubt that Ground came loose its almost impossible but it can't hurt to check.. The rest of the wiring is in the same place I've had it for well over a year and its all wired correctly with 4 GA wire and RCA/power on opposite side etc. I'll just have to check with the car off to make sure.. The subwoofer thats in there now making the vibrating tones sound perfect at higher volumes, no distortion or anything and actually I couldnt believe how much bass I got out of one subwoofer.. thanks for your help..
1991 Camaro Z28
CURRENT MODS:
STEREO MODS:
Old Oct 12, 2001 | 11:04 PM
84_l69_T/A's Avatar
is the speaker tight in the box?
Old Oct 12, 2001 | 11:05 PM
84_l69_T/A's Avatar
oops
84 l69 T/A
5 speed, 373 posi rear
comp xe262 cam
hedman hedders and y-pipe no cat edelbrock pipe and areo chamber muffler
performormer rpm intake
holey 750 vac,,tuned for the 305
accel hei w/msd 6a box
wp sr 305 heads,
stereo, 8 memphis power bass 10's,2 memphis 1000d amps,ohio generator 140 amp alt,tsunami dry cell bat,set of memphis power reference 4x6's,and a set of memphis studio 6.5's with a memphis power bass 400 amp on the highs....dbdrag comp car
Bubbajones_ya
Aug 31, 2015 12:02 PM
lt1z350
Aug 28, 2015 05:57 AM
86White_T/A305
Aug 17, 2015 12:16 AM
mustangman65_79
Aug 11, 2015 03:17 PM
z28addict8490
Aug 7, 2015 08:48 PM
