Amp with a stock delco unit?
Old Nov 1, 2001 | 02:35 PM
OldBlue's Avatar
Hey guys, I have a stock delco unit in my firebird ( Type wiht the EQ ) can I put an amp on it? I was thinking run the wires for the rear speakers to my 400 watt amp ( 4 channels ) then run an external cross over, the kind that have the terminals for the 6x9's and the other terminal for subs. that way I could power my 2 10's ( 300 watts each ) and power my 6x9's ( 600 watts each )Can I do this? or should I look for a used pioneer unit with the preouts? I cant buy a new one right now or else I would and it would bte GM fit one, I hate the looks of the regular players in our cars, with the big ugly install kit yuck. but If I can get a used one for cheap I will use it
Old Nov 1, 2001 | 04:08 PM
kream-'s Avatar
Yes you can buy line input converters just about anywhere...
Obviously theres gonna be more hiss and less quality coming from the speakers, but its still possible to have a decent sounding system like that...
(then when you DO upgrade to a real headset, you'll enjoy it even more from the better sound quality you get from your existing components)
however 80%+ of the people are going to tell you to go buy the headset now..
Old Nov 1, 2001 | 06:27 PM
CODY BEHNKE's Avatar
You wont get ant hiss if you get a decent down converter, not one from radio shack. But running it that way gets you about .5 volts line out. Where a good headunit will give you 2-4volts = better sound quaility to amp.
sailtexas186548
Jan 19, 2016 12:21 PM
mustangman65_79
Car Audio
Sep 8, 2015 08:20 PM
Irocohio
Aug 12, 2015 08:03 AM
ZsTransAm
Aug 11, 2015 07:30 PM
