Alternator
Old Mar 7, 2002 | 08:38 PM
5.0L1992RS's Avatar
Alternator
My alternator recently died, probably due to my amp. I was looking for a higher output alternator. I saw this one on ebay: 180 amp alternator. Is this good? Will it over charge my battery? Finally, is it compatible with my car?
Thanks,
Old Mar 10, 2002 | 11:15 PM
coalyard's Avatar
I am not so sure about the alternator on E-Bay, although with a bit of ingenuity, anything can be made to work;-) I do know for sure that GM/Delco sells 140 amp heavy duty alternators that should bolt right up to any F body engine configuration. BTW, 140 amps is more than enough for all but the most power hungry audio systems. Unless an alternator is malfunctioning, it will not over charge the battery, no matter what amperage it is rated at.
_________________
1988 Camaro RS 305ci TBI
Clarion 9255 source, Soundstream Reference 500, Reference 200, (2) Reference Class A 3.0 amps, A/D/S 326is fronts, A/D/S 325im fill, 3 JL Audio 8W6 subs. Stock alternator, no problems.
RS Reaper
Oct 17, 2018 07:52 PM
apie2546
Oct 16, 2016 02:24 PM
SRKLEGIN
Oct 3, 2015 10:11 PM
RS Reaper
Sep 27, 2015 07:04 PM
raymondandretti
Sep 27, 2015 06:43 PM
