Now what?
Old Nov 22, 2001 | 02:04 PM
91RedFire's Avatar
Now what?
Ok, so I took off the cover for the 6x9's in the back and I took out the speaker with a torch wrench. Now I have the new speakers and the old speakers. How do I disconnect the old ones? There is a blue and a black thing holding them together and I can't disconnect them. How do I do this? Thanks.
1991 Pontiac Firebird
51k Miles
T-Tops
Fire Engine Red
305 TBI
14" Edelbrock Element
"Pure Crempuff"
Old Nov 22, 2001 | 02:21 PM
91RedFire's Avatar
Well, I got the blue plug separated from the black one, but now the black thing is still on the speaker, and the new one won't fit without that device, so how do I put the new speaker on? It's my first speaker install so I'm just learning here
51k Miles
T-Tops
Fire Engine Red
305 TBI
"Pure Crempuff"
Old Nov 22, 2001 | 02:33 PM
deadtrend1's Avatar
well, heres where you run into trouble installing new speakers using factory wire. Since there is no standard with speaker wire connectors .... it makes it a pain. If you order speakers from places liek crutchfield, they give you adapters for your new speakers. Try calling up places tomorrow and see if they sell them. If not, then you have to do some riggin with solder and wire. B is the +. and A is the -. Im 99% sure on that.
1991 Firebird (GT40)
-LO3 305 TBI
-5 speed
-Open Element Air Filter
-Edelbrock Tower Strut Brace
-Kenwood Excelon Headunit w/ 10 Disc Changer
-Alpine MRP-F256 Amp
-Polk EX 4x6's, DX 6x9's, and EX Tweeters
-Kicker ZR240 amp (bridged)
-Dual JL W0 12" Subs
My page with pics and stuff, and car stereo help.
http://members.aol.com/deadtrend1/index.html
Old Nov 22, 2001 | 02:48 PM
TrueBlue91RS's Avatar
answered it while I was writing. I take too long
Just do what deadtrend said or run new wire. Stock GM wire is not very good quality.
[This message has been edited by TrueBlue91RS (edited November 22, 2001).]
Old Nov 22, 2001 | 05:49 PM
GndPrx's Avatar
If you don't care about retaining the original clip for the factory speakers, you can just cut it off and crimp on the connectors for the new speaker (usually come with the speakers or you can buy new spades that fit). If you want to retain the factory clip then you have one of two options...T-Taps, which I don't much recomend, but they get the job done...or run new wire from the deck or amp back to the 6x9 location (not very hard to do)
Carl
CarAudio Resources
CarAudio Resources Forums are now ONLINE!
Old Nov 22, 2001 | 05:59 PM
nagga's Avatar
go down to your local stereo shop and buy 30ft of Lightning Audio 14-16 gauge speaker wire, and redo all your speakers, its pretty easy to do, thats what i did, it gives u a better power transfer to your speakers from your deck, so it will make em sound a little better
Old Nov 22, 2001 | 07:07 PM
91RedFire's Avatar
Thanks for the help guys, I appreciate it. So if I wanted to just cut the wire and put the wire that came with the speaker, how would I do that? Should I just cut off the whole blue thing on the standard wire and attach that factory wire to the new speaker?
51k Miles
T-Tops
Fire Engine Red
305 TBI
"Pure Crempuff"
Old Nov 23, 2001 | 12:20 PM
91RedFire's Avatar
Ok, I'm going to cut off the blue adapter and just wire that wire to the new speaker. Hopefully I know what I'm doing
52k Miles
T-Tops
Fire Engine Red
305 TBI
"Pure Crempuff"
