Your thoughts on my box idea!
Old Nov 23, 2001 | 09:42 PM
Torqomeo's Avatar
As i said i have 1-15" Rockford HE2 sub. After some reading and posting here i found that they work best in large ported enclosures. Then I had to think of a box idea. What i decide on is to have the sub mounted in the middle and 2 ports one on either side of the sub. This should equalize the sound right? What do you think or do you have a better box idea?
Old Nov 23, 2001 | 10:36 PM
DJSexay's Avatar
if you want to do that for looks, go for it, but it should not sound any different than a box with a single port.
mike
Old Nov 24, 2001 | 01:19 AM
Torqomeo's Avatar
Yes, but won't i be able to half the port size if i use 2?
Old Nov 24, 2001 | 08:16 PM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
You can use 20 ports if you want to.
As long as the total volume of the ports is the same as the recommended volume that the manufacture says, then it'll work fine.
Just remember that the volume of a cylinder is
dia. x dia. x .7854 = area
Area x length = volume
This is the simple formula. Although it's not politically correct.
AJ
[This message has been edited by AJ_92RS (edited November 24, 2001).]
Old Nov 25, 2001 | 11:52 PM
Belker's Avatar
it'll work just as well as if the two ports were next to each other ... go for it
CarGuyDennis
137
Dec 6, 2016 11:02 PM
backtothe80s
Sep 5, 2015 12:39 AM
midias
Aug 15, 2015 05:07 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
mx127
Aug 10, 2015 08:13 AM
