CD Player in... everything but sound works...
I took my Stony Xplod cd player back 2 Circuit City and since it's been over 30 days they can't just give me store credit for somethign else. They send it back 2 the factory and then they fix it. So now for at least 2 weeks I'm stuck without anything. So I looked in our shop and found my old Pioneer that was in my car when I got it last year. Here's what I did. I wired the red... the black... and the orange up... then I wired the light blue wire to my light blue remote wire. I didn't wire the speaker wires up because all of my speakers are on my amp. Now my cd player comes on, lights up, the cd player reads and everything but there is no music. The amps do not come on so I'm thinking it's something in the remote turn on wire. Any ideas?
ok... i went out... turned it on... had it hooked 2 the light blue wire coming out of the cd player... nothing... cut it and ran it from the amp 2 the postive terminal of the battery... music... is there anywhere I can run this remote wire to??
the orange from the cd player... i just spliced into the orange wire with the fuse on it that was from the old cd player...
and what is this acc wire? where is it at? is it with the bunch of wires coming out of the harness?
most likely the acc is the red wire off your radio. yellow is constant (memory) and black= ground
And if there is a fuse, put the wire off the amp before the fuse ... so you don't blow it from drawing too much power. The fuse will probably think that having the remote from the amp on the same line is the Radio drawing to much power and blow.
Maybe not, its late and im pumped up on tylenol so waht im saying might not even hold grips to a rational thought.
~Tim
~Tim
Linson
Oct 1, 2015 09:50 PM
