Need help with wiring head unit/stereo
Old Apr 6, 2002 | 03:02 AM
ORAY777's Avatar
Hello. I am a new proud owner of a 1991 z28 1LE 5.7LITER Auto. I need help with the wiring because there is no wiring for the stereo. Do any you guys know where i should wire the red and yellow power wires into the fuse box? Will this process be complicated or should i take it to a stereo shop. I think the rest is pretty much straight forward with the power antenna, ground, and speaker wires.
Old Apr 6, 2002 | 06:37 AM
deadtrend1's Avatar
Well, you can pull down the fuse box and theres a fuse that says radio. Connect the red wire to that terminal. (theres pins on top of the fuse box and thats why you have to pull it down. As for the yellow ... try to find something constant.
The cigarette lighter wires are good because they are constant and close by. Or else run it right to the positive terminal to the battery but make sure theres a fuse inbetween that (cant be too safe).
Then finding a ground is easy enough.
~Tim
BTW ... Why is there NO wiring?????
midge54
Dec 27, 2019 04:14 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 07:57 PM
ZsTransAm
Aug 11, 2015 07:30 PM
