stupid choke light!!!!!!!
Old May 23, 2001 | 11:09 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
Mine went on yesterday when my car got hot to like 240 and now it stays on and makes a buzzing noise. can someone help me out please??
why does it do this and how can i fix it?
86 Z28:
350 vette
aluminum heads
T-5
235/60R15 BFgoodriches
dual 3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt Sony xplod amp
Sony xplod deck
K&N air filter
Old May 27, 2001 | 02:24 PM
CamaroMike's Avatar
The alternator is bad. The choke light doubles as an alternator light. The alternator closes a relay that allows the battery to power the choke. Battery voltage and alternator voltage are also pitted against each other on the choke light. When the alternator is bad the battery voltage is allowed to flow through the choke light and walla, light is lit.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Recently Ported Heads, Installed Larger Race-Flo Valves and RPM Air Gap Intake (No new times)
Other Mods: You name it and I have probably changed it.
2001 Dodge Ram Quad Cab 5.9L 4*2
The Bowtie
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old May 27, 2001 | 08:17 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
first the alternator has been charging the battery and the choke light just went out today. so i don't know what is up with it.
thanx for the help
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
Old May 28, 2001 | 12:17 PM
Teddy Z's Avatar
Did you check your fuses? The same thing happened to me last summer - I had an intermittent short that would blow a fuse which would trip the choke light/buzzing until I replaced the fuse. Eventually i found the short and permafixed it.
Old May 29, 2001 | 11:02 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
the light has been gone for a couple of days and i really didn't do anything. unless the bulb burned out. LOL but anyway it sometimes fixes it self.
thanx for the help!!!!
86 Z28:
350 vette
aluminum heads
T-5
20% tint
hatch wing
2 12"kicker solos
Sony xplod deck
K&N air filter
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
fasteddi
Sep 10, 2015 09:32 AM
TBRays98
Sep 6, 2015 05:05 PM
Jetmeck
Sep 4, 2015 12:29 AM
andy74
Sep 3, 2015 08:41 AM
