rods? or other problem
Old Jun 9, 2001 | 12:18 PM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
hey guys, i put world products sr torquer heads and a crane compu cam 2032 in my 305 and when you open it up using the 4bbl it boggs down and you hear poof poof under the hood, i'm unsure of the rods that are in there but it has a J hanger, i put a G hanger on, and it still does it but i dont think it does it as bad, i have some CC rods, would those work ok? or do you think i have another problem?
86 Camaro with 88 305 LB9 using 86 carb setup, edelbrock performer manifold, 305 S/R Torquer Heads, Hedman Headers, Crane Compucam 2032 edelbrock cat-back, gutted cat, slp underdrive pulley, mallory ignition, 305 h.o dual snorkel air cleaner, hypertech thermomaster chip,160 degree thermostat, 5-speed, 3.23 posi
95 Beretta Z26, 3100 V6, 4 Speed auto, stock
Old Jun 10, 2001 | 08:57 PM
Damon's Avatar
Could be. Check your rods first. If they are "CH" or "DP" rods you might want to go to something richer. My personal "go to, works every time" rods are "DRs"- same as used in the L-69 305 HO motor.
Most stock rods are on the edge of too lean with the stock peanut cam and low-flow intake. Open that all up a bit and they step over the line and go into "definitely too lean" realms and that can give you poppint through the intake.
Please note that's not the ONLY thing that can cause that by a long shot. Retarded timing, vacuum leaks, stuck EGR valve can all cause weird symptoms similar to that.
[This message has been edited by Damon (edited June 10, 2001).]
Reborn756
Sep 4, 2015 03:42 AM
mantaguy
Sep 1, 2015 08:39 PM
gixxer92
Sep 1, 2015 04:32 PM
Thaney9
Aug 29, 2015 03:16 PM
theurge
Aug 21, 2015 12:46 PM
