Thinking of putting the computer back in.......
I have an 83 Trans Am that the previous owner took out the computer and replaced the distributor with a vacuum advance version, and the carb with a non-ccc Q-Jet. Since I will drive this car absolutely everyday in all sorts of lovely Michigan weather, I was wondering if the car would be more reliable with the computer setup. how hard would this swap be?(the wiring harness has not been hacked) Does anybody have a computerized carb and distributor they want to sell or trade me? Thanks for any responses.
Car: 82 camaro SC
IMO, you won't make it any better with a CC Carb. The computer doesn't control all that much. It still uses a regular choke(for cold weather starts) and has most of the problems you have with normal carbs. Are you having troubles with the non computer carb?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
