Can a Holley 600cfm DP pass emissions?
Is it possible to pass? I need to be able to pass a sniffer at idle and 2500. I guess if all else fails I'll just have to swap the CC Qjet and distributor for the day of the emissions test. Probably the intake too unless someone knows a way to adapt a QJet to a Performer so it will fit under the hood.
Thanks,
Matt
Thanks,
Matt
Transmission: 4L80E/4L80E
Not in Colorado.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4. 2.93 limited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LG4 w/'87 LB9 block, ZZ3 cam and intake, World 305 heads, Hooker headers & y-pipe, 3" Catco cat & 3" cat-back).
57 Bel Air, my 1st car. '66 396, 9.7 CR forged TRWs, Weiand Action+, Edelbrock 1901 Q-Jet, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 600 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
Car: 2002 SOM z28
I don't know about a 600cfm... but a 750vac passes with no problems in NC! Visual too... I guess they couldn't see it under that big-honkin stock air cleaner
Vacuum leaks do wonders for the sniffer...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Let me expound:
Even if they don't notice the carb type in the visual, when they climb into the car, they turn the ignition to "on" and look to see if the SES light comes on. Then, they start the engine and look to see if the SES light goes off in the first few seconds. If either of these do not occur, you fail.
So, you take the bulb out so it doesn't glare at you all the time, they don't see the light come on, you fail. You leave the bulb in, the light doesn't go off after the engine is started, you fail.
If you want to go to the trouble of hooking up a timed relay to that SES bulb, be my guest.
By the way, the Performer is drilled for both square- and spread-bore carbs. And, it's more than a sniffer, it's a dyno test (unless it's an '81-older vehicle).
I would just leave the cc stuff on the test day then 20 min after rip it off. A neat trick that I used the one and only time I had to get a smog check when I lived in denver was to rig the check engine light to the choke light and it worked. You could also rig it two the fasten seatbelt light. But if you get caught your SOL.
SSC
SSC
Car: 2002 SOM z28
5.7... I don't know how they do it in CO, but here in NC at a Quick10/Jiffy Lube, they don't look at the SES light. They have a checklist and simply go by that. During that one day each year, I have to put the stock air cleaner back on (it doesn't fit a Holley too well either) for the TAC sensor. I have to put the AIR valves, hoses, and diverter thing on too. I lean it out a little and create a small vacuum leak, then drive to the shop early one Saturday morning on a cold day in March.
These guys here just go by the things on the list. It is so bad, that they look to see if you have windshield wipers, but literally will pass you even if you don't have a windshield... it isn't on the list!
I still keep my q-jet (with a broken base which needs to be replaced) and HEI in a box just in case someone gets wise and looks under the air cleaner...
They're a little more sophisticated in Colorado. It's the only thing this outfit does.
Car: 2002 SOM z28
5.7... I just looked at something on my car yesterday. I have replaced all the dash gauges and hooked up a light to the seatbelt light... which goes on for about 10 seconds when I first start the car, than it shuts off. Sound like what the SES light does?
BTW- I made lights for the e-brake and high beam indicator too just so I'd pass
Car: 82 camaro SC
emissions test, whats that?
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, current red metallic paint. Lots of other stuff...
82camaro
82camaro
<font face="Verdana, Arial" size="2">Originally posted by 82camaro:
</font>
</font>
---Grady---
1984 Berlinetta.
LG4 305
Holley #1850 600 c.f.m. carb.
Edelbrock Performer intake.
TH-700R4 tranny.
Flowmaster 80 series/ 3" cat-back pipe.
Accel Superstock Coil.
7.5 10-bolt rear/ 3.08's.
Edelbrock Pro-flow air cleaner.
Pioneer head unit, Pioneer front 4X6's, Cerwin Vega rear 6x9's.
Daily Driver.
Personal Quote: "The Rice-Boys all tremble with fear when the old American V8 draws near."
The only thing you have to fear is if the same people who run your elections would run your emissions program.
darwinprice
17
Oct 11, 2015 11:51 PM
Royal_Z
Sep 30, 2015 08:45 PM
